For those using FSR 2 in spiderman, might be worthwhile injecting the modded version as people are reporting better results with it over the official implementation:
www.reddit.com
Will tell you later on hunt showdown right now.Spiderman 4K Very High Settings + Ray Tracing with FSR 2.0.
Game runs very well, averaging 80 FPS, with 1% lows of 56 and a max FPS of 119.
Edit - @shankly1985, can you tell me what the latest build of the retail game is? It should say on the menu screen.
I dont see the build version on the main menu Matt?Spiderman 4K Very High Settings + Ray Tracing with FSR 2.0.
Sorry, I meant the pre-game launcher. I am using a beta key and want to validate that I'm on the final retail build (which I think might be 1.9 or something but not sure) so need someone with a retail key to check the latest version.I dont see the build version on the main menu Matt?
1% lows are within 24 FPS of the average FPS, those are good results and match up to the testing done by Computer Base. I may redo the video as I was not using exclusive full screen, so curious to see how better it would be (if at all) using that.That frametime looks anythin but smooth![]()
If you'd like to put up some results from your setup, running the same settings/resolution and benchmark sequence, with an overlay clearly showing the Average and 1% low FPS, please go ahead as I'd be interested to see it.Especially when ray tracing is activated, the frame pacing of the game is almost perfect, both the GeForce RTX 3080 and the Radeon RX 6800 XT show no significant deviation in the frame time history. Such a thing is rarely seen, at least minor outliers are usually the order of the day. Without ray tracing, frame pacing is still very good, but interestingly enough, it doesn't quite come close to the excellent level of rays. So there are some deviations in the frame output on both the GeForce and the Radeon.
v1.812.1.0can you tell me what the latest build of the retail game is?
Thanks Tommy, same build then.v1.812.1.0
Btw make sure you are running in exclusive full screen mode. If you alt tab (like I did in my previous video before recording) it switches you to borderless (full screen) mode.
I can't see his posts (and never will), so as you commented on my video performance that's why I asked you.I will leave that to @Nexus18![]()
Because you said my performance looks bad, so I am assuming yours is good, don't see why you'd make a comment otherwise.Why did you bother to do that though? What is the point in comparing cards from different tiers? Not to mention I do not have the game yet and will be getting in around winter sales or after once it is under £20![]()
Because you said my performance looks bad, so I am assuming yours is good, don't see why you'd make a comment otherwise.![]()
Find a random video online, use that as 'evidence' to point towards a supposed issue. Then ask me to explain it. Case closed I guess?
Let's dig in to that one a little bit again to remind ourselves what actually happened. Pay special attention to the frame time overlays, because only one of them is showing bad frame times associated with VRAM saturation.
3080
6900 XT
Local system issues indeed.![]()
The game runs very well, with no stuttering or other issues that I could detect.
