Thanks just done that and it worked, although mine is showing range as 509miles rather than km like the dash is, id be happy if it would do 509miles on a tankFor correct fuel consumption and range, goto the OBC section and disable Low OBC Calculation.
This fixed my consumption and range figures.
My car's averaged 12.9km/l over the last 3 and a bit years I've had it. So if I used every drop of fuel in the tank, I'd be able to do 505 miles.Thanks just done that and it worked, although mine is showing range as 509miles rather than km like the dash is, id be happy if it would do 509miles on a tank![]()
thats what ive been trying but its not changing itYeah you can change that in the app, set the units to miles and the dash display will change too. There's also an app called Car Settings if I remember right which controls what stuff shows on the dash, like a speed warning if you reach a defined speed and stuff like that
	I hotspot from my phone which works automatically, as soon as bluetooth connects when I get in the car, Samsung Routines enables hotspot mode and the head unit connects to the hotspot. Turns off when I leave the car and bluetooth goes out of range.
