- 28 Dec 2017
- Beds
Energy =/= power.Sure, if you reduce the flow rate to 50% for the latter.
Energy =/= power.
We really don't need to get into the differences between power, time, velocity etc and energy as a fixed amount regardless of those factors. I doubt jpaul was being quite that specificHeat transfer is proportional to both velocity and surface area
My thermostat sets the boiler Central heating temperate automatically it takes from around 25c to 60c. I've set the hot water to 52c.So what's everyone setting their combi's to? Not put much thought into it previously but I've dropped mine to
70 on the heating from 75
50 on the water from 55
Those were the factory figures
Just to see how it runs, won't know on the heating yet but the water seems to be taking longer to heat so surely that's counter productive because the boiler has to run for longer?
Same with the heating, surely it'll just take longer to hit the target on the thermostat if the water running through the rads is cooler?
There's some placebo effect in this. The boiler will start on full power to get the water up to temperature as quick as possible, so technically it'll reach temperature quicker. However, because the water temperature is lower, it may feel like it's taking longer because it just isn't as warm, especially so if you have a mixer tap and don't open the tap on full heat first until the hot water comes out, then mix to the correct temp.Just to see how it runs, won't know on the heating yet but the water seems to be taking longer to heat so surely that's counter productive because the boiler has to run for longer?
There are downsides to gas ovens which is why people get rid of them in the first place.
What downsides in particular?There are downsides to gas ovens which is why people get rid of them in the first place.
Gas ovens are not as good as electric but gas hobs are miles better than standard electric. Ideal combo for me is a decent fan electric oven, gas burner.They are a ***** to clean (hobs) but I do like our gas hobs
Interesting idea, just dropped the heating to 50C and see how it goes when the Mrs starts mithering for it to be switched on in a couple of weeks. I'll gradually up it so it's more effective as it gets colderWeather compensate the heating yourself. I posted it somewhere else here. As it starts to get cold, I set my heating to flow at 50C. When that doesn't heat the rooms, I up it by a few degrees. When that stops working, a few more degrees etc until I reach what I consider the maximum reasonable temp - 70C.
Some systems do this automatically, but you either need weather data or external temperature sensors.
I've taken the hot water down to 45 too
I'm far too lazy.Gas hob at my old house, the cleaning alone is good enough reason to not have oneI'm far too lazy.
