- 7 Nov 2017
compression shouldn't affect sag (also don't set suspension up using sag). It doesn't have much in the way of range for compression as stock so you are unlikely to see anything. It is a **** damper mind you.
How many tokens are in the fork? I personally don't rate any of the RS or Fox stuff at all.
Consider this https://www.novyparts.com/optimisat...hox-fourches/optimisation-specifique-zeb.html
