USB boot via android
2 Dec 2004
Under The Desk, Wales
Guys. I need your help.
My daughters pc has gone kaput and i have ordered a new cpu and mobo.
My issue is that i have no win 10 DVD as the current one is cracked in half. I have a genuine windows key though.
I cant download and make a bootable Win 10 DVD or USB as i got no pc to do that from.
Can i make a bootable usb with win 10 on it via Android?
Edit:
Just seen this. Will this work / reliable?
Depends if your android device supports(/works with) the OTG cable you get. If the cable works and is able to read/write to your USB stick just fine then i don't see why it wouldn't work.
What's the device you're intending to use? Phone, tablet? What model?
My phone.
In case it does work, which phone is it? I know some manufacturers don't implement all features on the USB port (eg Google blocked display out). Samsung is usually pretty good covering everything.
