- 9 Apr 2012
There is a physical device that will do it, can’t recall what it is called now. I wanted to try it but never got around to it
iPhone 11 which I’ve had since launch is now at 74%. I’ve noticed the drop off in battery life over the last few months.
mines exactly the sameiPhone 12, just under 2 years old, battery is on 87%
mines exactly the same![]()
Iphone 11, almost 4 years old, 71% and showing "Service" i charge every night with optimised charging on. Might spend the £69 and get the battery sorted as nothing out really justifies spending hundreds of pounds and anything more than my £10/10Gb a month tarrif. That said i still get a whole day of use out of the phone.
3 years old. It was released in 2019. Mines at 87% from launch and mines mostly charged on my drive to and from work. With an hour commute each way that's usually all the charging I ever have to do.Iphone 11, almost 4 years old, 71% and showing "Service" i charge every night with optimised charging on. Might spend the £69 and get the battery sorted as nothing out really justifies spending hundreds of pounds and anything more than my £10/10Gb a month tarrif. That said i still get a whole day of use out of the phone.
Coconut the best out there.Why don’t they show battery health on the iPad in the same way? Are there any apps you would suggest to see this. I’m not convinced my iPad battery is that great for a newer device.
Thanks, yes I have a Mac. So it's a Mac app rather than an iPad app? I will give that a lookIf you've got access to a Mac then CoconutBattery will show the battery health along with design capacity and actual capacity on iPads as well as iPhones. I'm not aware of a similar tool for Windows but there must be something.
