- 21 Jul 2005
- Officially least sunny location -Ronskistats
Is this the new heat sink for the 4000 series?
How big is that chip
PHAT THICC
No way in hell the chip is wide enough for all those heat pipes, but it's on the internet so must be trueignoring everything else, look at dem heat pipes
$400 extra for another 4g of RAM for the 4080?![]()
Based on my own speculation for prices for ADA, current pricing for Ampere, and leaked TSE scores. Sadly table function on this forum seems kinda borked so I had to do it as an image. Was mostly curious to see if Ampere's worth buying now, and which ones to look out for on the second-hand market, mostly eyeing the 3080 Ti/3080 12G as of now, it seems competitive with 4070 and I don't believe Nvidia's going to jebait us with it at $499 again (which was a lie even 2 years ago for 3070). Guess we'll have to see in a few days if it even gets announced.
Problem with that is typically the AIB watercooled cards take at least 12 months to turn up after the release of new cards, or at least that was the case with the current gen.My Meshify C is worried, 315mm GPU length limitI'm doubting I'll be able to get a 4080 under that size now, and maybe not a 4070! Or I'll have to fork for a watercooled option
The 4080 16G is a different die to the 4080 12G. The 4080 12G would usually be the 4070 if you follow previous NVidia convention. Seems they want to split the market further...$400 extra for another 4g of RAM for the 4080?
Because last time round people saw the small difference in perf but massive difference in price and noped away from the 3090 and got a 3080 lol. This time round they are making the physical spec quite a big jump for the 90.wow seems the gap between the 4080 (proper) and 4090 is much larger than 3080 and 3090
It's worth it for those diehard farcry fans.$400 extra for another 4g of RAM for the 4080?
WTF, I still need a better GPU for Resident Evil 2 1998.It's worth it for those diehard farcry fans.
Like a French policewoman's arse.PHAT THICC
The next GPU change for me will be all about efficient performance.
Then a 3080 Ti forever it will beHmm, but you could be waiting forever for that, it'd be like standing on a train platform waiting for the train to stop but it never does
Very rounded corners for contact with a square cornered die. It's either larger than needed or the die has a cap.This is what the bottom of the card looks like after removing the PCB, you can see the indent where the GPU die makes contact. Someone should get out digital calipers, we can now measure the size of AD102
Manufacturing square pockets is hard, and you're likely to have quality issues with the corners. It's just design for manufature.Very rounded corners for contact with a square cornered die. It's either larger than needed or the die has a cap.
Easier to machine a rounded corner, so probably cost saving.Very rounded corners for contact with a square cornered die. It's either larger than needed or the die has a cap.
It is believed that an amount of that is dedicated to a large amount of cache, similar to infinity cache.Also, holy crap. Rumours that AD102 is a 72B transistor chip!!! https://videocardz.com/newz/nvidia-ad102-gpu-reportedly-has-more-than-75-billion-transistors
If true, this thing is going to be >2x faster than the 3090TI, which came in at 28B transistors.
The 4080 16GB having a different die to the 4080 12GB is making more sense. The top of the market has just found a new ceiling, and surely a new price.
This is going to be a fun release! My 2p is that NVidia will have the fastest cards, but AMD will win the value proposition while competing with NVidias 2nd tier.
