- 30 Mar 2017
Very nice! It’s a regular EVO case right not the XL? Asking as I have an EK Lumen on order and planning to fit where you have yours. Cheers,Dan.
@jammir Thanks for that info. I imagine it looks better with screw holes you made I am guessing? I am not that handy even though I have built custom loops, when I get drills out bad things usually happen!
Top class advice. I had to do something like that to fit an external rad in my H700 that is being retired. I know what the first thing I will be doing when the Lumen arrives now, desecrating the Evo it’s got to be done. Hopefully it’s easy to bend and doesn’t break off the rest of the case causing some apocalyptic event. Thanks for the pic as well.
Incredibly tidy build - could I ask what thickness radiators you've got? I think they're 45mm?Very nice! It’s a regular EVO case right not the XL? Asking as I have an EK Lumen on order and planning to fit where you have yours. Cheers,Dan.
That's thicker than 45mm. It's the new EK XE Quantums at 58mm instead of 60mm Coolstream.Incredibly tidy build - could I ask what thickness radiators you've got? I think they're 45mm?
Liking the Bykski block. Waiting for one of those myself. I take it this is a 3000 series 3 pin PCIE card?My first build here. The focus of the build was on simplicity and performance.
Its KFA2 GeForce RTX 3090 HOF, Ill share the full specification in a spoiler.Liking the Bykski block. Waiting for one of those myself. I take it this is a 3000 series 3 pin PCIE card?
I like your style. I have an Aqua Computer Next as well and the same tubing. Looks beautiful, well done!Its KFA2 GeForce RTX 3090 HOF, Ill share the full specification in a spoiler.
Watercooling specification
Rads:
CPU Block: EK Water Blocks EK-Quantum Velocity² D-RGB - AM4 Nickel + Satin Titanium
- front: EK Water Blocks EK-Quantum Surface X480M + 4x Phanteks T30
- side: EK Water Blocks EK-Quantum Surface P360M X-Flow + 3x Noctua NF-A12x15
- top: EK Water Blocks EK-Quantum Surface P360M + 3x Phanteks T30
GPU Block: Bykski N-GY3090HOF-TC,Dual Active GPU Backplane Block For GALAX RTX 3090 HOF
Res/Pump: Aquacomputer ULTITUBE D5 NEXT 150 PRO with Leakshield
Flow meter: Aquacomputer Flow sensor high flow NEXT
Tubing: EK Water Blocks EK-Tube ZMT Matte Black 9.5/15.9mm
Fittings: EK Water Blocks EK-Quantum Torque Satin Titanium
Temperature sensors: 2x Alphacool Eiszapfen temperature sensor 2xIG1/4 - chrome
Bulkheads: 2x Alphacool Apex Fillport - chrome
Water mix: Aquacomputer Double Protect Ultra Clear
PC specification
CPU: AMD Ryzen 9 5900x
GPU: KFA2 GeForce RTX 3090 HOF
RAM: G.Skill Trident Z Royal 64 GB, 4000MHz, CL18
MBoard: X570 AORUS MASTER
PSU: EVGA SuperNOVA 1000 P2
Case: Corsair 7000D Airflow
Cable riser: EK Water Blocks EK-Loop PCI-E 4.0 Riser Cable - 200 mm
Absolutely stunning. Well done.
Hey, just got around to installing the EK Lumen. Installed with the USB adapter to mobo that goes USB to USB type C into the Lumen. I get the EK logo but no display. Would I just be able to ask if that is how you have yours installed and if you may have any other advice? Have tried a few things in windows. It’s not recognised. Thanks! Edit: I didn't realise the other cable provides video, so an easy fix hopefully! The product page makes it sound like you just use one cable and the other HDMI to USB was for external use.
That is a lovely build. I haven’t see a GPU mounted that way before either. Is this customised or is a bracket for that mount available to buy?
