- 22 Dec 2006
- Around Town
You'll notice I said I have kids, thats not how you make babiesThat's what swallowing is for. Don't blast it over the bedding.
Perhaps I just have a bigger machine (9kg) then... I can get bedding and towels in the one load (I could get a few towels plus bedding in there) Also, I don't separate darks from whites. It all goes in the one load and I've never had an issue.
Towels/Bedding - I know of someone who uses 2 towels every shower and then doesn't use them again until they have been washed.... How dirty can a towel get off a clean body used once?
If you haven't got a full load in your machine (emergency washes aside) then it's kinda daft putting it on.
Marvellous things, just make sure it has a good warranty.That's what I've heard too. A heat pump drier will be our next big purchase.
That's cause you on fixed. People should adjust their usage figure with standard variable to compare. Otherwise the I pay £50 is meaningless. For instant on current variable that £40.60 becomes £56 ish. And come October will be £67 for those 24 days.66 a month??
My 3 bed with 2 adults only is 80 a month.
Edit.
I tell a lie. It's 50.just checked my bill!
40 for 24 days.
So about 50 for a month
We have a bathroom plus two ensuites and cloakroom toilet, plus towels in the kitchen. So the hand towels alone make up 1/4 of the load. Then 4 sheet towels plus a seperate towel for my wifes hair makes up the rest. Theres absolutely no way I could fit kingsize bedding in with that too, even with a 9kg machine.
The kids swim every week too, and their swimwear / towels need washing every few weeks.
You're right, there are definitely some extremes. We use towels daily for a week (sometimes twice a day if I've had a run). They are definitely ready for a wash at the end of the week thoughGranted I have 2 less ensuites so 2 less hand towels. I think the a part of it the use of, and number of, bathsheets as it's just bath towels here which are significantly smaller.
As I say, there are people who wear or use something once and even just for an hour or so and then it's straight in the machine. Some of these people then make statements about how expensive their machines are and that they MUST use a tumble dryer else their house is "like a Chinese laundry"
Have 2 in the house and are washing machine & dryer normally does around 55 cycles per monthI'm keen to be educated differently here but I don't see how, even with a family of 4, people have the washing machine on 6 or more times a week (unless it's a tiny tiny machine)
Have 2 in the house and are washing machine & dryer normally does around 55 cycles a month
It's not the heat with causes the wear, it's friction. The longer you tumble the more wear.Heat pump driers are a lot kinder on the clothes.
What are the benefits of a Heat Pump Tumble Dryer? | Beko
Did you know that Heat Pump Tumble Dryers are better for your health and general hygiene of your home? See more Heat Pump benefits in this Beko infographic.www.beko.co.uk
Three in the house and our washing machine goes on usually once, sometimes twice a week...Have 2 in the house and are washing machine & dryer normally does around 55 cycles a month
Mainly yes, unless washing large loads (it 12kg washing machine) and then would split that into two drying loads..55 cycles each?
Mainly yes, unless washing large loads and then would split that into two drying loads..
Help me out here... There must be a good reason a 2 person household needs their washing machine to be running almost twice a day?
I work in a very dirty (dusty & oily) job 6 days a week so my work clothes, bath towels etc are washed separate 6 days per weekHelp me out here... There must be a good reason a 2 person household needs their washing machine to be running almost twice a day?
I guess that explains it more.. I take it you're claiming an allowance for cleaning your own work gear?I work in a very dirty (dusty & oily) job 6 days a week so my work clothes, bath towels etc are washed separate 6 days per week
That's a point.. I know you can claim tax relief for washing your own work uniforms.. Are the government gonna increase that in line with electric rises?
, it’s been the same amount for as long as I can remember.Not that easy as work supplies overalls which i don't wear as i don't like wearing overallsI take it you're claiming an allowance for cleaning your own work gear?
