Thinking more about this, i don't think AMD would have them, they don't have the market share, it would spread supply to others too thin, and literally this.....
4080 will be sometime in NovemberHow long until benchies? I'm keen to see by how much the 4080 12 stomps my 3080Ti
EVGA was Nvidia's top partner in North America and with their popularity in the enthusiast community, AMD would take them in a heartbeat. They might get limited stock allocations in the immediate future but will be able to get more, especially if doesn't come at the expense of existing AIBs and instead comes from growth in market share.
I suspect this will happen but they might skip a generation until new management comes in at EVGA.
No, not technically. That would be like saying everyone with USB 1 are now getting USB 3 simply because you can plug a USB 3 device into a USB 1 port.
Nvidia have tried to pull the wool over peoples eyes, the only feature that makes DLSS 3, DLSS 3 is the frame generation feature without that what do you have? DLSS 2 is what.
Well it's not "you lot" as i said that, no one else. Secondly: Yes argument. Or are you not giving reasons why you support an idea or suggestion that DLSS 3 can be used by previous generation cards? Because it sure seems like you're making statements called premises intended to determine the degree of truth or acceptability of another statement called conclusion (maybe it would help if you looked the word argument up in a dictionary).
No i do not concur, for the very same reasons you've had explained to you on multiple occasions now. If as you claim there's some other new feature of DLSS 3 then you're more than welcome to say what that is, because simply forcing an existing feature to be turned on is not a new feature (not that i accept your proposition that people using a 30 series card will have Reflex forced on whether they want it or not).
Yes Nvidia said Reflex is integrated with DLSS 3 but as you've been told that's because frame predictions undoubtedly introduces latency, if you're not using the frame prediction feature of DLSS 3 then Reflex is not needed, if you're not using the frame prediction feature of DLSS 3 then you're not using DLSS 3, you're using DLSS 2.
Reflex has been a feature of DLSS since version 2 so no, i do not concur. Simply forcing something to be used is not a new feature, it's a requirement for the use of a new feature. Saying it's a new feature would be like saying TPM is a new feature of Windows 11, it's not, it's a requirement.
Also no i do not concur that frame generation is 1 of the 3 features of DLSS 3, DLSS 3 only introduces one extra feature, frame generation, the other two are features of previous versions. If someone forces you do do something before doing something that's not a feature, it's a requirement.
What next, are you going to claim that breathing is a feature of wanting to live?
In a pre-release version of Cyberpunk 2077’s new Ray Tracing: Overdrive mode, DLSS 3 enables DLSS Super Resolution, DLSS Frame Generation, and NVIDIA Reflex to boost performance by up to 4X, and increase responsiveness by 2X, compared to native resolution, all while maintaining great image quality.
Don’t over pre order this time4090 now live on the site, more cards shall be added daily.![]()
4 x 8pin connectors on that PNY 4090, is that a typo?4090 now live on the site, more cards shall be added daily.![]()
The official PNY site says you need a 4x 8pin to 1x 16 pin adaptor4 x 8pin connectors on that PNY 4090, is that a typo?
The card has an 12pin the same as the founders 3080ti/3090/3090ti cards looking at it so unless the image is incorrect it’s looking like a normal draw. PNYs site could be wrong just as the image could be as that’s definitely a 12 pin and not a 16 pin on the image on the sales page.4 x 8pin connectors on that PNY 4090, is that a typo?
Can anyone confirm 4090 will deliver 144hz on 4K via dp 1.4a on dp 1.4 monitor? Example Dell G3233Q
PNY GeForce RTX 4090 VERTO EPIC-X RGB 24GB GDDR6X PCI-Express Graphics Card
Order PNY GeForce RTX 4090 VERTO EPIC-X RGB 24GB GDDR6X PCI-Express Graphics Card now online and benefit from fast delivery.www.overclockers.co.uk
Not bad price!¬
You seeing something we aren't? no price on that![]()
Must have been edited then![]()
No price means they are freeYou seeing something we aren't? no price on that![]()
@Murphy I put a couple a quid in the prayer box for you.![]()
