Overclockers current priceIs that at Overclockers? Or another site ? The more i think about the more I'm swayed towards the FE![]()
Could be a power issue and Nv want to keep their card within a certain envelope. Might stretch its legs with 600w+Anybody care to guess why 4090 seems to be underperforming?
Arguably it started happening with the 10 series (6 years ago) as that's when Nvidia profits started climbing from a little over $2bn a year to the heady highs of more than $15bn per year.It isn't 40x0 that has put up prices, it happened with the pricing of stuff like the 3090 Ti. If people are buying at those prices, why wouldn't they build cards to that price point?
My guess would be because they've used a lot of the silicon budget on their Deep Learning, AI, fake it until you make it, ray tracing stuff.I dont understand 1 thing - taking pure increase in raster power(around 1.5x more shaders and 1.5x higher clocks vs 3090ti), 4090 should be around 100%-125% faster than 3090ti. While even Nv shows somewhere between 70-50% for raster-only games.
How come? FE is 1679...
Yes, but look at the increase in MHz - 3090ti was boosting to ~1800Mhz. 4090 is supposed to boost to 2500Mhz. That's 1.38x. 1.38x*1.6x =2.24xIt's got something like 60% more cuda cores that don't translate to a simple 60% improvement so that's why it could be less than that % improvement.
The only problem is that this gen your not going to get 3090ti performance for £650, the 4070 which is likely to be priced at that level now will only just match a 2 year old 3080. The cards are not only being priced higher but the actual performance of all but the 4090 is weaksauce.Next time, Nvidia should announce their lower end cards first. Then people would be like OMG! 3090Ti performance at 3080 prices!? This is amazeballs!
You are probably right, I got back and checked 3090ti vs 3090. Theoretically around 15% faster on stock, but it only translated to 9% more performance. So the % you mentioned will explain it.1% more cores doesn't mean 1% more gaming performance, especially true for Nvidia - the 60% extra cores only probably accounts for 20% or 30% higher frame rate in games, the higher clocks probably account for another 40% and then depending on how bottlenecked the game is, the SER adds another 5% to 35% extra performance - this why RTX4090 has a wide performance range, one game can be just 50% faster and another can be 90% fafaster
Except that when you look at DF's video comparing this exact scenario, the DLSS3 footage still looks smoother - i.e DLSS3 at 120fps looks smoother than native 60fps
I asked the Asus rep on FB and was told more info will be released later so probably under embargo until near release , i assume the strix will be up there considering the 3090 strix could go up to 480w ( 520w with a bios ) ... will probably be 4 x 8 pin pcie connectors via an adapter.
DLSS resolution scaling is quite well understood by now - it's not stretching, but generating additional pixels as predicted by a machine learning model. If the model predicts text accurately then it doesn't need to lead to blurring. It doesn't work even close to perfectly of course, but the potential is better than purely upscaling from information that's in the current frame or with the addition of motion vectors.Doesn't DLSS stretch an image supersampled to to the preferred resolution? therefore small text becomes blurred? Higher frames for cost of image quality.
MSFS 2020 for example they didn't show any images of the instrument panels, and DLSS has been known to cause them to blur from the new update. I'm sure we will see the impact to games Vs image quality of small texts and jagged edges.
You mean 4080 16GB, NVIDIA has posted all the MSRP's up and it starts from £1269, so again AIB high-end OC models will cost more:
4080 12G from £949 and again AIB high-end OC models will cost more.
MSRP is for entry level SKU / FE card.
Also remember the 4080 12G and 4080 16G are very different cards, the 16G version is not just 4GB extra memory, it is 256-bit VS 192-bit and also 9728 VS 7680 Cuda Cores, so the 16GB is a far more powerful card.
