- 22 Mar 2017
- Poland
Colin McRae Rally my lovely game. I was 14 years oldRemember buying a 1mb memory chip to upgrade it. Colin McRae Rally never looked so good!
Had a Matrox Parhelia hereOld enough to remember 3DFX vodoo gpu :/
Just a thought,
Given the excess glut of 3000 series cards still available, has Jensen killed two birds with one stone?
Has he deliberately priced the 4000 series so high, that people will baulk at the price and go buy a 3000 series card, clearing stock, while at the same time maximising the money fleeced from the fanboi crew that MUST have the latest and greatest 4000 GPUs. Until such times as 3000 card stocks are done, then he can reduce the prices of the 4000 series cards to snare the people who sat waiting for prices to come down, around the time the 4080ti is launched?
i reckon the FE will have a hard limit of 500w so i doubt we will see 600w go through it unless we get an unlocked bios ( unlikely ) or you want to shunt mod it ... what PSU have you got ? not enough power or not enough 8 pin sockets ? i recently changed my PSU to a Corsair Hxi 1200w and have a couple of spare 8 pins even though 3 are in use for the strix so should be ok with psu , hopefully a company like cablemod releases an all in one cable that has 8 pins at one end and the new pcie5 at the other so we can get away without an adapter .
I think the same and Disappointed there are not AIO water cooled options on release. Nvidia claims to have hit 3ghz overclocking these but the AIB models seem to max out around 2.6ghz. Seems like water cooled is the way to hit 3ghzWhen you see the card without the cooler they are very small IMO. The new gen are really screaming out to be water cooled.
Had a Matrox Parhelia here![]()
yeah man its a no-brainer dlss is the future of graphics rendering, the leather jacket guy is making the right strategic bets, the guy has vision, if it werent for nvidia we would have been waiting till the 2030's for a dlss like solution, thats 12 years wasted
Nvidia has indirectly released some performance numbers for Cyberpunk 2077, the numbers are reported from journalists today who were shown a closed door demo while performance stats appeared on the screen. The tests were done using a pre release version of the game that has further enhanced Ray Tracing quality than what the live version does today.
EVGA 1600i so plenty of power but the adapters concern me. Each pci-e 8 pin connector is only really rated for 150W and I see some AIB are supplying 3 x adaptors and so should be 450W max whereas others like zotac are going for 4 x adaptors so can supply 600W. I see corsair with their Thor PSUs only supply a two way so should be 300W max but in testing 300W were going through each pci-e so they have now changed the listing to max 450W but thats still more than what should be going through each pci-e connector.
The new 16 pin pci-5 5 gen connector can supply 600W directly so interested if you use that to connect to a FE will it take up to 600W and if using the adaptor its only 450W as its only a 3 -way?
Like you say, should be able to buy 4 way adaptors hopefully later on.
The problem with that though is ampere still isn't that cheap considering its 2 years old now and has also been cut off from the newer tech features like DLSS 3.0Anyone esle not even in the slightest bit interested in this round of cards? Maybe it's me and my age (late 40s) but this just looks like a joke from my viewpoint. Perhaps also that as I've got older, my gaming has decreased to a point where there is no time to game and I've lost interest. Plus there are no good games out that even slightly pique my interest these daysI guess I'll stick to what GPU I have and just mosey on....
On games like Cyberpunk if you want to use RT, then it is a must. 3080 Ti here, with RT set to psycho and everything else ultra @ 3440x1440 it's in the low 20fps range to low 30s average. With DLSS enabled in Performance mode it's in the 70-75 fps range. With Gsync ultimate that fps feels like the smoothness of 100+ fps however on OLED so there is that bonus too.I've never used it,
ZOTAC RTX 4090's PCIe Gen5 power cable adapter service life is up to 30 connection cycles - VideoCardz.com
Unplug your GPU only if necessary According to ZOTAC, one should remove power cable adapter carefully and only when really necessary. If you are one of those people who replace or remove graphics cards frequently, make sure to count how many times have the power cable adapter been used. ZOTAC...videocardz.com
