Not if fully WC with large rads and slow fans.Do you think its going to be reasonably difficult to run these chips in a silent system?
I think they will run but performance will not be beast mode. You need space to exhaust the heat.Seems impossible to get the full performance out of these chips in an ITX chassis like the Dan A4
Interesting, thanks, wonder how much louder a 240mm AIO is over the DRP4... I suspect I'd prefer a more silent machine than say an extra 100MHz from PBO2.It will work yes but will it allow max PBO2 boost I dont think so...
Also it depends what you consider acceptable temps....Interesting, thanks, wonder how much louder a 240mm AIO is over the DRP4... I suspect I'd prefer a more silent machine than say an extra 100MHz from PBO2.
It's difficult as AMD seem to have made 95c acceptable, so I think my opinion needs to change too. Ideally would see some reviews of this pairing to see how competent it is.Also it depends what you consider acceptable temps....
Does it allow per core overclocking?7700X at 5.4 all cores should be OK on that cooler... and stay within your 95c limit....
Don't have time unfortunatelyYes, watch 8 Pack's video in the original post, he discusses this
Cant discuss products we are stil under NDA on.what would you choose, 7950x or 13900k and why??
I tried yes but consistency of temps with LM across every core is not easy to obtain at all. To do this you need a lot of trial and error and testing. If correct it does work well though..@8 Pack - Have you or will you have a go at deliding and cooling the die's directly?
The ones we tested all worked well on this... Others I cant comment.. ROG HERO, ROG extreme, GIGABYTE MASTER and in MATX ASUS ROG GENE.Friend of mine has bought the 7950X but is confused about motherboard choice when it comes to what would be the minimum recommended power-stages to get the most out of the chip. She does heavy compiling, streaming, 3D modelling and light gaming. Any suggestions on motherboard choice basically..
