So no specific links to specific posts. FiguredIt was literally yesterday. shows how much rubbish you post when you cant remember. I'm done
Everyone else knows what the person is posting about. Just trawling through to find it isn't worth the time. But it was the single run CB23 results you didn't like and then tried to claim you need a 30min run etc. You made complete rubbish your argument and you change direction more than the wind to try and make a point.So no specific links to specific posts. Figured
The best CPU for gamers will be the one with lowest dollars per frame so probably a 12600k like now or a 13600k...Zen 4 vcache is going to be the best CPU for gamers. The 8 core version will be cheaper than 13th gen i9 CPUs.
RAM won't make much difference.
Enough said?
But that doesn't explain how was I wrong. The stock guidelines from intel (you can check their website btw) is pl1 125/240 56 TAU. Other than that, of course mobo manafacturers are free to change it, but stock is stock, and in stock configuration it is absolutely true that the 12900k is more efficient than the 7950x also at stockEveryone else knows what the person is posting about. Just trawling through to find it isn't worth the time. But it was the single run CB23 results you didn't like and then tried to claim you need a 30min run etc. You made complete rubbish your argument and you change direction more than the wind to try and make a point.
Probably the most antagonistic person on this forum imo.
It's same rubbish when you talk about stock and say the 12900k is 125w stock but it isn't in terms of taking it out box and plugging it in. It's 241w and that what "stock" scores get you out the box. Yes because mobo vendors set it but that is what stock means. What happens when the system is set up and runs out box. Doesn't matter if the cpu 'stock' 125w if a user will never see that unless they go manually set PL1 to it as mobo set PL1=PL2 as example.
Ryzen does out box by CPU and Mobo design use 95c thermal boost to get most which is actually beyond its best efficiency curve when in stock.
But since you have to set 12900k to PL1 125w you can also do such for the 7950x as example and that outscored the 12900k at 241w even. The Zen4 series can be extremely efficient if you set one of the eco modes and still get more performance that stock. Look at the chart showing 85c and 75c eco modes and it scores better than stock cause its able to boost higher whilst keeping lower temps and pulling less power.
You deny anything written in front of you but the fact that 65watt 7950x beats out the 12900k at 241w means that over a 30min run AMD would always be on top for that workload in comparison even if you hampered yourself by doing so.
The 16900k is going to be the best CPU for gamers. You know what i mean? Yes, a newer cpu that is not going to be released for at least 6 more months is going to be better than an older cpu. Even if that is indeed the case, big whoop. Lets wait and see, and until then talk about products in the here and now?
Because you are reading a sales pitch figure that is not real world where PL1 125 is never utilised by itself because PL1=PL2 241 by all motherboard manufactures to maximise the performance and sod all given to the efficiency available. So has nothing to do with spec sheet stock if you are not getting that real world. The stock real world because of how the ecosystem works is 241w not 125w.But that doesn't explain how was I wrong. The stock guidelines from intel (you can check their website btw) is pl1 125/240 56 TAU. Other than that, of course mobo manafacturers are free to change it, but stock is stock, and in stock configuration it is absolutely true that the 12900k is more efficient than the 7950x also at stock![]()
Man, i think you dont get the context. Im not trying to say the 12900k is more efficient than the 7950x, because obviously it isn't. Out of the box settings - for me - are absolutely useless. The thing is, back on alderlake nobody cared that you could set PL1 to whatever you wanted and make the 12900k extremely efficient. But now that amd released an inefficient cpu at stock, everyone is talking about power limiting it. Don't you see the double standards? Cause I do.Because you are reading a sales pitch figure that is not real world where PL1 125 is never utilised by itself because PL1=PL2 241 by all motherboard manufactures to maximise the performance and sod all given to the efficiency available. So has nothing to do with spec sheet stock if you are not getting that real world. The stock real world because of how the ecosystem works is 241w not 125w.
You have gone on to state you placed your 12900k at 125watt PL1 to set it to stock in previous posts.
AMD have the same feature in Ryzen Master so you can just set that to either 105w or 65w eco modes. Even the 65w R23 results out perform anything the 12900k can do because it scores higher than the 12900k can ever achieve. AnandTech for instance have the 65watt mode scoring 31,308pts so that is 481pts/w. The 12900k at 125w scored 26,890 so that is 215pts/w. So that would suggest that the 7950x is supremely efficient in comparison.
If you want to continue to run the whole 7950x 170w vs 12900k 125w to make a point then fine but literally nobody else (maybe Dave2150) is reading anything like this in anything that is being provided with tables and data points. You could have the 12900k at stock PL1 in fairness if you are only using a low end mobo where the manufacture has not set PL1=PL2 but honestly whom is buying a £90 mobo for a £500 CPU?
But you are missing is that most people at 'stock' was 241watt not the 125watt setting. So Intel with their spec sheet yes it would be more efficient out the box at 125w, however real world settings stock for 95% of people with the 12900k is 241w because of the mobo spec setup and so that is real world stock vs spec sheet stock that is being discussed.Man, i think you dont get the context. Im not trying to say the 12900k is more efficient than the 7950x, because obviously it isn't. Out of the box settings - for me - are absolutely useless. The thing is, back on alderlake nobody cared that you could set PL1 to whatever you wanted and make the 12900k extremely efficient. But now that amd released an inefficient cpu at stock, everyone is talking about power limiting it. Don't you see the double standards? Cause I do.
Also, btw, the 12900k does not score 27k at 125w. If that's what anandtech said, they did it wrong. It scores around 24 to 24.5k. Im just saying, that with the official intel specs, the 12900k is indeed more efficient out of the box than the 7950x at stock. I find it funny, but whatever
Seriously?The best CPU for gamers will be the one with lowest dollars per frame so probably a 12600k like now or a 13600k...
x3d are only good at low resolution and stupid expensive anyway, they make the 4000 series look cheap
exactly not worth it... £410 for last gen cpu thats rubbish outside of gamingstill got the 5800X3D beating Raptor Lake in some games, it costs around £410 in the UK.
already discussed, should have gone to spec savers or learn to read a chart if you can't see itTrying very hard not to highlight the performance of the 5800X3D.
Do you have some kind of personality problem?exactly not worth it... £410 for last gen cpu thats rubbish outside of gaming
