I like the idea of using the trays for smaller wood, where'd you get them from?
Yeah, mine is bad for that as well. She still doesn't get the 'man make fire' thing yetthe Mrs declared she was too hot and not to put any more logs on![]()
Get with the times fella, asymmetric is inThey don't match ????-- Come on pull yourself together.
I am now going to call them biggy and shorty.
I'm also thinking as I'm about to order some wood that it's better to order a half pallet of just ash and make kindling from some of it, rather than order less wood and some kindling.
Some heat logs as well purely for great as they're much cheaper than logs.
What was that gadget someone in here mentioned for splitting logs/kindling?
Make my own but not from hardwood. What then I've looked on eBay and it's all either hardwood IE oak or MDF rubbish.I wouldn't personally make kindling from decent hardwood / seasoned logs.
Either buying (although expensive from most places for what it is) or making your own would be the best way to go
I got some untreated joiners offcuts which make perfect kindling
In terms of the "gadget" it is exactly the one you linked in @JonRGV250 post![]()
That's a good idea, I'll have to keep an eye out for wooden pallets.I take a pallet home from work, cut it up on the mitre saw, 2 pallets is enough to fill a bin and just about enough for winter.
They’re ideal, just try and find untreated pallets.That's a good idea, I'll have to keep an eye out for wooden pallets.
