Project: Raptor Lake
29 Nov 2006
Massive thanks to Intel for asking me to do a build for them.
Thought i would share by build log for the project
System Specs
1 x Intel cpu under NDA
1 x ASUS ROG STRIX Z690 -E GAMING WIFI
1 X ASUS TUF GAMING RTX3090 OC 24GB
2 x Corsair Dominator Platinum RGB DDR5 5200MHz 32DGB
1 X Corsair HX1200w PSU
1 x Samsung 980 PRO 2TB M.2 NVMe
1 X EK Quantum Velocity CPU Block and backplate
1 x EK Quantum Vector RTX3090 Block
1 x EK Quantum Kinetic 360 D5-Distro
2 x EK Quantum Surface S360 radiator
10 x EK Quantum Torque fittings
16 x EK Quantum Torque 90 degree fittings
4 x EK Quantum Torque 45 degree fittings
8 x EK Quantum Torque rotary offset
6 x EK Varder X3M D-RGB fans
2 x EK Cryofuel Navy Blue
1 x Antec Cannon case
Looking very nice so far. Not seen really looked at this case before and it sure is funky.
Obviously your build is nowhere near complete but I do have a question. The internal components you have painted all seem to have a distressed look, are you planning similar style for the extrernal painted panels as well?
Obviously your build is nowhere near complete but I do have a question. The internal components you have painted all seem to have a distressed look, are you planning similar style for the extrernal painted panels as well? Thanks yes the panels will be weathered and distressed
