Project: Raptor Lake
29 Nov 2006
Massive thanks to Intel for asking me to do a build for them.
Thought i would share by build log for the project
System Specs
1 x Intel cpu under NDA
1 x ASUS ROG STRIX Z690 -E GAMING WIFI
1 X ASUS TUF GAMING RTX3090 OC 24GB
2 x Corsair Dominator Platinum RGB DDR5 5200MHz 32DGB
1 X Corsair HX1200w PSU
1 x Samsung 980 PRO 2TB M.2 NVMe
1 X EK Quantum Velocity CPU Block and backplate
1 x EK Quantum Vector RTX3090 Block
1 x EK Quantum Kinetic 360 D5-Distro
2 x EK Quantum Surface S360 radiator
10 x EK Quantum Torque fittings
16 x EK Quantum Torque 90 degree fittings
4 x EK Quantum Torque 45 degree fittings
8 x EK Quantum Torque rotary offset
6 x EK Varder X3M D-RGB fans
2 x EK Cryofuel Navy Blue
1 x Antec Cannon case
12 Jun 2021
Leeds
Looking very nice so far. Not seen really looked at this case before and it sure is funky.
Obviously your build is nowhere near complete but I do have a question. The internal components you have painted all seem to have a distressed look, are you planning similar style for the extrernal painted panels as well?
OP
29 Nov 2006
Obviously your build is nowhere near complete but I do have a question. The internal components you have painted all seem to have a distressed look, are you planning similar style for the extrernal painted panels as well? Thanks yes the panels will be weathered and distressed
