*** Microsoft Windows 11 Thoughts & Discussion Thread ***
Anyone had any issues with Battle.net since the last update push (not 22H2).
Unable to update CoD since the last reboot/update installation. Needed to reinstall the lot.
Not sure if it's Battle.net, CoD or W11 at this point.
They have removed up time from task manager which is annoying.
How are we supposed to see up time now.
(I think we can do it by typing systeminfo in command prompt).
:confused:
I checked new task manager and uptime is still here. I am on 22H2, uptime is not removed in task manager.
I think I need a bit of help as getting confused.......
Currently running Windows 11. I have tpm on mobo but I had to use the reg edit to install it as my cpu is old.
I'm getting no updates regarding the 22H2, but I've read that you can update Windows by downloading the ISO. But wouldn't that just reinstall Windows?? :confused:
Run the setup file to upgrade and you'll keep all your apps, files and settings.
I got the 22H2 via Windows Update and i think it may have reinstalled windows anyway.
I have a "Windows.old" folder on my C drive again.
