In the land of make believe @Purgatory![]()
Nvidia's msrp is just an ....
in the ..
You think people would have learned that over the last two generations by now (20 and 30 series).
Tbf it does come with a free river...In all honesty unless the Stix is under £2000 which it wont be then I'm getting the FE card![]()
Trouble is these will have upto 500/600W going through them, which is pretty much unknown territory right now! Just get as long a warranty as you can get, you may need it...How long do the AIO coolers last compared to standard fans?
Basically an FE 4090 if prices hold at the MSRP Nvidia gave us and a water block = £2k... what a joke. We all know they will end up being hard to get and the AIB prices are made up and will all end up over £2k and £2.5K for any decent model.
The Nvidia fake msrp games again and the fake shortages coming soon to make sure you buy the AIBs. ..fool me once, shame on you, fool me twice, shame on me, comes to mind..
Price wise the FE with a stock EK block is coming in at £1856 or £1966 with the Active backplate .... both quite a bit cheaper than some the AIB prices going round
I will just hold out till i get an FE at msrp , im not paying over the odds just to get my hands on one as i don't need it that badly
So what are they cooling on the backplate? Seems ridiculous if there isn't any memory there. Its made my decision for me though.
I was slightly tempted before but the information I have seen says the FE keeps around 50c at full load so you would expect the AIBs to be even better. As it runs cool anyway the AIO cooling is most likely not needed and for an extra 700 against the FE price it’s is a ridiculous price proposition.Trouble is these will have upto 500/600W going through them, which is pretty much unknown territory right now! Just get as long a warranty as you can get, you may need it...
Jensens itinerary.Basically an FE 4090 if prices hold at the MSRP Nvidia gave up and a water block = £2k... what a joke. We all know they will end up being hard to get and the AIB prices are made up and will all end up over £2k and £2.5K for any decent model.
I reckon this to be false, maybe at full fanspeed outside of a case and in a temperature controlled environment yes, but in a case with decent airflow I'd expect 65/70c easily.but the information I have seen says the FE keeps around 50c at full load
Anyone seen the size of the strix 4090?! It's not much smaller than a ps5!!!
It looks like a massive ugly metal box. Like some kind of meme. A GPU for giant people, basically comical
Summertime , PC stays cool ... me on the other handThey will all be singing this once they get one and stick it into their case not designed for such a high power device in it and summer time they will realise the reality (coming from a guy with dual 3090's in a very large case that is well cooled and cards run at safe temps but the room in summer is another matter)...
30+ deg ambiant temp outside and then put on a 650w+ spaceheater
Summertime , PC stays cool ... me on the other hand![]()
These 4090's if they are warmer than 3090's will seriously dump some heat out that people are not used to!I recall HDTV test did a video on 240 or even 300hz oled I think? Get ready for the next levelThen you will need a new OLED that can handle over 120fps as your wasting frames!!!![]()
I recall HDTV test did a video on 240 or even 300hz oled I think? Get ready for the next level![]()
YOLO or if you can afford the 4090 and OLED's then another OLED upgrade isnt going to hurt is it?![]()
