just got my shipping email![]()
Ditto.
On Trinity none OC the BIOS is locked,
I'm not too fussed about overclocking.
well he defo is a villain selling it over £1k above what he bought for only a few hours ago.Is... is he a Bond villain?
I think they would with OCUK splashed all over it !Tbh i don't think they will care as much this time round as scalping is way less prevalent than 30 series.
name and shame , these thieves spoil it for those who really want one .
Horrible pink sticker (warranty void if removed) on the near edge of the backplate ruins that card for me. No issue if you vertically mount it though!me too
its a beast, faster than the strix yet cheaper, in my opinion its the best looking card period.
plus 5 year warranty.
this is exactly why i mentioned it .I think they would with OCUK splashed all over it !
If you let Gibbo know in a PM they will get the order cancelled if they find out who it is.
(Actually you cant PM him)
Too much for Jensen to supply a longer power cable to hide that mess....OMG my PSU doesn't have 4 independent connectors .....
they are CPU/PCIE though maybe I could daisy chain :S
I'm gonna ask phanteks support or seasonic and see what they say
I'm planning to set the power limit to 60% though so I Guess it doesn't really make a difference if I'm only on 3 connectors.
BTW this card the bios switch on mine is set to silent not gaming by default
The stupid anti sag bracket doesn't really work with my case, if I put it down the void near the front fans then it's not a flat surface down there so I have to pit it where it is now.
The wires touch the glass side panel btw
Looks like the FE's sold quickly but had about half an hour of availability in the US on one of the sites.
I would say don't risk it and just get a new PSU that legit actually supports it.they are CPU/PCIE though maybe I could daisy chain :S
I got the add to basket button. Then it said product is unavailable when you clicked itI didn't even see the add to basket button on the UK site.
yea I said that days ago that the connector is so short that you can't cable manage... would an extra 30cm made a difference to nvidia margins really...8 watching the giga £3000 4090.
No, I do not touch it on global level (as that affects all apps in Windows, not just games and can cause undesirable effects, as AMD engineer said in different topic). I enable it in games usually and only in NVCP if game is old and doesn't have such option. However, I also always disable triple buffering in games (this is what causes a lot of delays in mouse movement etc.) and in NVCP I set Low Latency mode to Ultra (as that is designed to work very well with vsync and g-sync together, as even description says so in NVCP).Hmm interesting, so does that mean you have vsync enabled at a global level in NVCP and leave the vsync option disabled in games?
I got it 3 minutes to 2pm but nothing happenedI got the add to basket button. Then it said product is unavailable when you clicked it![]()
I meant to specify non-FE availabilty for half an hour on one site in US.I didn't even see the add to basket button on the UK site.
