yep me too. Same card!!was able to get a zotac trinity oc just there now at another retailer happy happy man
Wonder how this will affect undervolting on the 4090. Might not be worth it this time.
Will check later, it’s out for delivery!
Thanks bought onethe other place has stock now
not mine just thought id post
It's a GPU on a leading edge TSMC 4nm node not a space heater, 600w on the 4090 is pointless.I may send mine back.
At £2000 plus change it should have been a 600W card.
Glad I have a Haf 700 evo as the Aorus Master is a chunky boy!not mine just thought id post
Guys what do you think about these:
Colorful RTX4090 NB EX-V
Inno3D RTX4090 X3 OC
They are currently available in my country and they are also the cheapest.
For 200 euro more MSI GeForce RTX 4090 Gaming X Trio there is also this which I can afford.
And there are no more stocks, some prices are insanely high in some retailers.
As you asked nicely!
Mine is going in an Evolv X, where it has plenty of room - but tried it in my family rig (O11 air mini) for you before I install it in the EvolvX. Fits easily, though have to remove the bottom fan mount!
Poor fella
Was posted on Reddit couple days ago - the gigabyte cards don't fit into the O11
