Or just read the max gpu size on case websiteAmazes me that people will spend around £2k on a GPU without doing a simple measurement first, only takes a few seconds.
Thats not very true.That's the stuff here :-
Honeywell PTM7950 SP Super Highly Thermally Conductive PCM Pad
Buy Honeywell PTM7950 SP Super Highly Thermally Conductive PCM Pad for £4.46 with Free Shipping Worldwide (In Stock)www.moddiy.com
See problem now for people that want to water cool their 4090FE/AIBs (guessing AIBs are using PCM TIM too) is they will need to get PTM7950 pads/paste or use liquid metal, reason is this pad/paste is only second best to liquid metal and normal thermal paste can't match it. So heads up to people taking them apart for thermal paste changes as this is not normal thermal paste but a phase change pad/paste. Used a lot in laptops and sensitive equipment that needs heat removing quickly.
Lenovo laptops uses a custom version pad PTM7950 and called PTM7958, Alienware laptops use Element 31 PCM paste basically a version of this stuff, etc more custom ones too and all highly electrically conductive too, so don't get this on electrical parts like liquid metal. So if you don't know the TIM method used on a device don't just guess it's thermal paste because it's grey and looks like that when removed as that can cause issues later and hot spots. This stuff doesn't weep out (pump out) like thermal paste over time so don't go replacing TIM on a 4090fe/AIBs unless you have new PTM7950 pads/paste version or you want to risk liquid metal.
So you have been warned now and if you replace the paste and wonder why it's running hotter this is why also new cards or PCM TIM change may show higher temps at first few hours until the stuff settles after a few thermal cycles.
This is the paste tube version that can be used too :-
Honeywell PTM7950 SP Super Highly Thermally Conductive PCM Paste
Buy Honeywell PTM7950 SP Super Highly Thermally Conductive PCM Paste for $19.99 with Free Shipping Worldwide (In Stock)www.moddiy.com
Honeywell PTM7950SP Super Highly Thermally Conductive Phase Change Material (PCM) Paste Thermal Interface Materials
PDF from Honeywell for this stuff :-
Phase Change Materials
Phase Change Materials (PCM) are often used as matrix materials for thermal interface applications.thermalmanagement.honeywell.com
Hey all, I'm new to the forums but have recently upgraded from a 3080 10GB to a 4090.
It was a bit of a job getting it to fit in a NZXT H400 but using slim line fans on the front of the AIO radiator I just about managed it!
Looks like there's room for a triple thick front rad, tons of spaceEven the O11D XL struggles with the 4090
My Zotac fits in the 011D XL pretty nice tbh and that's with a load of watercooling stuff in there as wellEven the O11D XL struggles with the 4090
Let's hope I can fit 4090/4080 in my 5000d airflow ;D
PCM is used because they know that due to die structure conventional TIM will be pushed out. That's why its also used in laptops. It's not any better than good TIM in thermal conductivity.
Very thick pastes like Thermalright TFX have proven better than PCM in laptop applications so I would be very surprised if it turned out any different in gpu application.
Its not like PCM is a breakthrough material. It existed for years.
You will certainly not need it on properly designed waterblock.
Yeah it was meant to be £100. Think it covers up to £30,000I thought that there was a minimum you had to pay to qualify. Something like £30 or £100.
Your debit card is not covered in the same way as a credit card. Even if you pay £100 on a credit card for a purchase that costs say £15000, you stil have cover on the full amount.
Guys I just purchased some PSU - PCIE Cables but they are Corsair ones ( Type 4 ) Will it be ok to use these on my Seasonic PSU ??? I'm hearing mixed opinions online..... Can someone confirm if its ok to use that cable.
That’s even better then. At least I got the 1 rightActually the first one (before edit) was right. The £100 minimum for Section 75 protection relates to the full cost of the purchase, not how much you put on the credit card. i.e. as long as the purchase amount is more than £100 (and less than £30k), you can put £1 or even 1p on a credit card and the rest on a debit card and you still get the full protection.
Section 75 refunds
Section 75 protects your purchases over £100 if you use a credit card. This MoneySavingExpert guide tells you how to claim if something goes wrong.www.moneysavingexpert.com
The product or service you're buying must cost over £100 and not more than £30,000 to be covered. Crucially, though, you're still covered even if you only pay a deposit of 1p towards an eligible purchase on credit. You're also covered if you've since closed the credit account you made the purchase with.
.what about EVOEven the O11D XL struggles with the 4090
Lenovo laptops uses a custom version pad PTM7950 and called PTM7958, Alienware laptops use Element 31 PCM paste basically a version of this stuff, etc more custom ones too and most highly electrically conductive too depending on the custom versions that have more metals in them like the Element 31, so don't get this on electrical parts like liquid metal. So if you don't know the TIM method used on a device don't just guess it's thermal paste because it's grey and looks like that when removed as that can cause issues later and hot spots. This stuff doesn't weep out (pump out) like thermal paste over time so don't go replacing TIM on a 4090fe/AIBs unless you have new PTM7950 pads/paste version or you want to risk liquid metal.
Plenty of room in the Evowhat about EVO
