Because its a load of BSThen why have various YouTube channels been stripping and rebuilding cards and not hitting any issues and not mentioning it at all?
That's what hammers are formy 3080gb suprim x 12gb is 140mm wide,example im seeing 4090 gaming oc which is 150,2 wide and im looking into my evo and honesty im not sure its gonna fit..
Time may tell, the main benefit of this PCM TIM is it lasts a long time and doesn't pump out or bake like some pastes do in time under high heat from the components being cooled or the many thermal cycles. So other pastes being used maybe fine for a few months but in time may show worse temps as they are slowly getting pumped out or baked to death under the high temps, where the PCM TIM can take really high temps and doesn't pump out easily. Read the specs of the PTM7000Then why have various YouTube channels been stripping and rebuilding cards and not hitting any issues and not mentioning it at all?
That's because even though it's called the Dynamic XL it's still the same narrow width channel because the PSU is hidden to the right, I know I've got the XL and even though I didn't know the sizes of the GPUs at the time of purchase I'm glad I got the Inno3d now because I've managed to fit mine in my XL with the glass panel closed also, Albeit justEven the O11D XL struggles with the 4090
yea what a silly designThat's because even though it's called the Dynamic XL it's still the same narrow width channel because the PSU is hidden to the right,
Seems a few here are having problems with the cable.Gpu itself will fit for sure,but with 12pwr cable i dont think so.
Because its a load of BSAIBs are not using PCM
I agree and kinda wished I didn't get this case now, Calling a case an XL and it's the narrowest case I've ever owned not to mention imho I don't know how it got such good reviews for build quality because imo it's not the best build quality at all, It's flimsy panels that rattle like a rattle snake no matter which panel you tap and it cost me over £200 notes.yea what a silly design
Guys so I just installed the 4080FE and halfway though updating the drivers the PC shut down and now won't even considering booting. There is power to the MB, light is on, ethernet port flashing. I've taken the 4080 out, reset cmos and still nothing. I can't believe it tripped or blew the PSU installing new drivers, if it had I wouldn't have expected to see any lights on the MB and its been running a 3080 just fine and that draws 350w gaming. I'm out of ideas.
Gigabyte Z490 Master
10900k
Corsair RM850X
Flip the switch at the back to off on the PSU before you unplug the psu from the wall wait a minute plug it back in and flip the switch at the back to on, use the IGP on the cpu for video without the 4090 in to see if anything comes up.
What psu are you using? Sounds like your new gpu may have drawn too much power and tripped the psu? Possibly a power spike to kill the board if it is indeed the board.It won't even attempt to spin up. Push the power button and it just does nothing.
So I just unplugged CPU power cables and used a jumper on the 24 pin that tricks PSU into spinning up and it did and radiator fans turned on. So I don't think its the PSU. FFS I'll take the CPU out and see if I can get the MB to attempt a Q-Flash, if it won't then its likely the MB is dead. What the hell could have caused that?
