Benchmarking Competition - Novabench
For some reason this benchmark doesnt like 3090's !
...turns out 3070 Ti > 3090 (at 1280x720) according to Novabench's charts. I guess 3090s should stick to 4K...
Rectangle Font Parallel Number Screenshot
My 5600X itx living room pc. Due to EDC bug in recent Agesa versions (lower vccore with any additional edc setting over stock), PBO doesn't work as well as it used to and raising it from stock will give me lower scores here. PBO is on with default limits with -30 CO and 0 boost override. Teamgroup pcie4 nvme is in use but limited to pcie 3 on this board.
- Windows 11 image included just for reference not the board.
5950x. (PBO 140edc bug limit +50 Boost -CO 20-29 across cores) Windows10 seems to knockout better scores than windows11 by not an insignificant amount. Especially noticeable with the gfx test averaging 140fps in win11 and 150 in win10 as well as the ram scores. Unfortunately for me, win10 sits on a 970evo producing a low drive score.
I have a feeling that this benchmark doesnt take into consideration dual cpus. Just managed to score 7570 with a Dual Epyc 7713 workstation i am currently building.
Yeah I ran into the same problem. Novabench will not recognize more than 1 numa node. What you need to do is go into the BIOS and disable numa and then re-run the test.
If it's still not accurate go into task manager and set CPU affinity for novabenchGUI.exe. You should be able to check all the cores at that point and they should be listed under a single node.
Hello,
Can I update mine?! No idea wahat was wrong with my FSB in the initial run, but I refreshed my bios (with the same version again) and then started from loading optimised defaults.
FSB, DRSM, etc. looks good now!
5600x & RX 6600XT (Sapphire Nitro+) My system, settings are Ryzen Master OC Mode Autoclocking and GPU is set to AutoOverclock in AMD Adrenaline. No idea if it's good, bad or indifferent lol I really should look into properly OCing this at some point
Novabench Link
