Yes.My road has just been enabled for full fibre... It's half the price of Virgin. It's it worth the move?
Without a shadow of a doubt.My road has just been enabled for full fibre... It's half the price of Virgin. It's it worth the move?
Yes.
That was my instinct. There's good cashback deals too....
I'm just now thinking where to put the ONT socket as ideally I'd like it installed near/into my small IT rack but I guess as long as I have a cable to it (which I do) it's not the end of the world. I'd just like to free up the study from being the point of access.
Thanks !
Ok. I'm sold!
I've not had issues with virgin but always found them overpriced.
Is it Openreach? If so look at Aquiss. Fantastic service and performance.
Mine was about 2 weeks, after that installed the CBT on the pole before I could order it.Fibre just went up the pole for my house. Hope I can order fttp soon![]()
About 10 days here. Ordered GB from aquiss this morningMine was about 2 weeks, after that installed the CBT on the pole before I could order it.
Just bin the whole unit.
Openreach don't even install the battery backup these days so I would just ditch it.I can just remove the batteries from my battery back up unit on my ONT right? But I’ll still have to have the battery backup unit plugged in to pass through power to the ONT correct?
The batteries have failed after 7 years, or at least the fault light is showing. Although oddly we never had a voice service along with it, so technically the batteries were never really needed.
I've been using a Billion router for my FTTC but the wireless just decided not to show up one day so I was put back on the Smart Hub 1. People have been complaining in peer to peer that I'm lagging. Pinging bbc.co.uk is seeing weird jumps: https://i.imgur.com/OzdDAgI.png
Is there anyway to limit these spikes? Never really happened on the Billion so the Hub is just not good enough to handle the amount of devices attached even when mostly idle? Around 10 or so. The problem is am I am likely moving to FTTP soon so how do I go about not using the Smart Hub 2? Is it better or also just horrible? Are you able to use an all in one modem/router or always have to daisychain off to a router from the Smart Hub 2?
