Had some decent share returns this year earlier than expected, so took the opportunity to put some money into a brand new build. Having always cautiously budgeted in the past on "previous but one" gen kit, it was exciting to be able to throw a little caution to the wind and fully update this time around.
Budget was 6k, but, despite Nvidia's best attempt, still didn't come close to it.
Much haribo was eventually consumed in the delivery of said items...
The eventual spec:
Corsair O11D Evo Case
Corsair Professional Series HX 1200W '80 Plus Platinum' Modular Power Supply
MSI MPG Z690 Force WiFi - Intel Z690 DDR5 ATX Motherboard
Corsair Dominator Platinum RGB 32GB (2X16GB) DDR5 PC5-44800C36 5600MHZ Dual Channel Kit - White
1x WD Black SN850X 1TB SSD M.2 SSD
2x Seagate Firecude 530 SSD's
Corsair Hydro Series iCUE H150i Elite LCD - 360mm
Lian Li O11D EVO Front Mesh Kit – White
Lian Li O11D EVO Top I/O Kit – White
Lian Li O11D EVO Vertical GPU Mount
10 x Lian-Li UNI SL120 Infinity Fans
Intel Core i7-13700K CPU
Zotac GeForce RTX 4090 Trinity GPU
Some of the bits...
Got a bit impatient, and started test fitting/building. CPU arrives at the end of the week
A bit of cable management needed!
I wanted the GPU in a vertical configuration. I haven't seen many 4090's at all in this config at the start, so wasn't sure if it would all fit, thankfully, it does. The RAM, being quite tall, was the biggest concern!
I've ordered a cablemods 12vhpwr cable as the supplied adapter cable into the Corsair cables just creates a horrendous mess. Since the GPU is vertical, i don't need to worry about waiting for a right-angle 12vhpwr cable.
The eventual spec:
Some of the bits...
