Eero 6 (3 pack) MESH Setup
28 Jan 2011
Hey guys,
after a lot of hassle and problems with the Netgear extender etc, I went with a Eero mesh setup.
I have just finished setting it up, and performance and signal is really good between rooms..
The only thing im wondering, is when switching between rooms, the signal drops for a brief second to 5G before connecting back to the mesh network.
It doesn't affect the internet, im assuming that its just distributing the connection between points as I go from room to room?
If someone can clarify fro me that would be great. Cheers.
yep, been running these for a little while now, getting decent speeds and the main thing I wanted, stability and connection. Happy.
I had issues before with certain model phones where transitioning would briefly drop to 5g and then wifi would come back. I found that it was usually a problem with dhcp. Try assigning the device a static ip on the lan. Does that help? If not, sometimes the advanced WiFi settings on phones nowadays can be an issue. In particular one device I struggled with was a Google pixel phone. Hand-off should be seamless though.
I’m not sure where this myth of seamless hand-offs comes from but it’s impossible to drop one radio signal and pick up another without interrupting the transmission. There are protocols in place that buffer the data but VOIP and WiFi calling will still often drop if you wander around and change your connection point. And that’s with any multi-station WLAN system.
That doesn’t sound like what’s happening here though. It sounds like the phone has decided that the 5G signal is a better bet than the WLAN so it drops it until it decides WLAN is better again. Which is what it should do. It’s what it does when you leave home, or the office.
I suspect the WLAN coverage isn’t as good as the OP thinks it is.
When I had the issue described, the WiFi icon would disconnect, 5g would appear then about 2 seconds later, WiFi would reappear.
When this was happening I used the signal meter app to move between nodes and the signal would start good, move down in strength and then drop completely. Big gap in the chart then it would reconnect on the other node, and strength would be good again.
Since I resolved my issue none of that happens. I can move around, wifi remains connected. And using the same signal application I can see the hand off between nodes occur and there is now no drop / gap in the process. Unlike before.
I can be in voice calls (real-time traffic) and transition around OK on WiFi. No loss or drops or changing over to 5g. So for me and from what I can tell, it is seamless. Having owned 2 prior mesh systems to this one, it certainly never acted like that before.
I wonder as you say though, if the OP potentially could have a dead spot where the range isn't overlapping enough between the nodes.
EDIT: Here are some screenshots to help explain what I was seeing, mentioned in my post.
This is the handover, as of now, with everything working OK. WiFi does not drop. This is me walking from one end of the house to the other and the handover between the two nodes (554 > 004) about halfway inbetween.
And this is what happened when it did as the OP describes. Note the big empty gap. That was the WiFi disconnecting, 5G connecting, then WiFi reconnecting. Which shouldn't happen (works as shown above).
hey guys,
As my Vodafone BB goes live next Monday, can I manually disable the WiFi and only have the ethernet ports active?
This is so I can use my Eero mesh as the primary wifi and ethernet source (as I have used a couple of switches through out my setup).
For when my broadband is up and running, and I connect my Ethernet cable from the router to my Eero unit, so I plug the Ethernet cable to ome of the four LAN ports, or the WAN port?
cheers.
I managed to pick up the Eero Pro 6E 2 pack in the Black Fridays sales - 40% discount. My BT Mesh has been working poorly for a while now and I'm looking forward to replacing with something potentially faster and more reliable. :)
BT Mesh is actually a very good product so I wouldn’t automatically assume Eero would be any better.
The most common issue with ISP supplied routers and gear being ‘poor’ is people put them in cupboards and behind the TV which is a very effective WiFi shield.
Nice one mate! Im sure you will enjoy them, thery are very very good products.
I have used the BT MESH discs and although they are decent, I am more impressed with the Eero setup. Both for connectivity and speed. (using online speed testers to get a "rough" indication.
AM i right in thinking Amazon have or will soon enable Mesh activation on their latest Echos, so if your running Eero Pros i think your good to go....
