Deleted member 258511
Can you just request the hub 5? I’m currently on the gig but have hub4, is there much difference if any?
| Network access | Allowed |
| Maximum Number of CPEs | 1 |
| Baseline Privacy | Enabled |
| DOCSIS Mode | 3.1 |
| Config file | d;kfoA,.iyewrkldJKDHSUBsg |
| Channel | Frequency (Hz) | Power (dBmV) | SNR (dB) | Modulation | Channel ID |
| 1 | 339000000 | 5 | 42 | QAM 256 | 26 |
| 2 | 139000000 | 7.7 | 42 | QAM 256 | 1 |
| 3 | 147000000 | 7.6 | 42 | QAM 256 | 2 |
| 4 | 155000000 | 7.5 | 42 | QAM 256 | 3 |
| 5 | 163000000 | 7.3 | 41 | QAM 256 | 4 |
| 6 | 171000000 | 6.9 | 41 | QAM 256 | 5 |
| 7 | 179000000 | 7.2 | 41 | QAM 256 | 6 |
| 8 | 187000000 | 7 | 41 | QAM 256 | 7 |
| 9 | 195000000 | 7.1 | 41 | QAM 256 | 8 |
| 10 | 203000000 | 6.8 | 42 | QAM 256 | 9 |
| 11 | 211000000 | 7 | 42 | QAM 256 | 10 |
| 12 | 219000000 | 6.7 | 41 | QAM 256 | 11 |
| 13 | 227000000 | 6.5 | 41 | QAM 256 | 12 |
| 14 | 235000000 | 6.2 | 42 | QAM 256 | 13 |
| 15 | 243000000 | 6.1 | 42 | QAM 256 | 14 |
| 16 | 251000000 | 6.1 | 41 | QAM 256 | 15 |
| 17 | 259000000 | 6.1 | 42 | QAM 256 | 16 |
| 18 | 267000000 | 6 | 42 | QAM 256 | 17 |
| 19 | 275000000 | 5.9 | 42 | QAM 256 | 18 |
| 20 | 283000000 | 6 | 42 | QAM 256 | 19 |
| 21 | 291000000 | 5.9 | 41 | QAM 256 | 20 |
| 22 | 299000000 | 6 | 42 | QAM 256 | 21 |
| 23 | 307000000 | 5.7 | 42 | QAM 256 | 22 |
| 24 | 315000000 | 5.6 | 41 | QAM 256 | 23 |
| 25 | 323000000 | 5.2 | 41 | QAM 256 | 24 |
| 26 | 331000000 | 5.3 | 42 | QAM 256 | 25 |
| 27 | 347000000 | 5 | 41 | QAM 256 | 27 |
| 28 | 355000000 | 4.8 | 41 | QAM 256 | 28 |
| 29 | 363000000 | 4.8 | 41 | QAM 256 | 29 |
| 30 | 371000000 | 4.9 | 41 | QAM 256 | 30 |
| 31 | 379000000 | 5.1 | 42 | QAM 256 | 31 |
| Channel | Locked Status | RxMER (dB) | Pre RS Errors | Post RS Errors |
| 1 | Locked | 42 | 0 | 0 |
| 2 | Locked | 42 | 2 | 0 |
| 3 | Locked | 42 | 0 | 0 |
| 4 | Locked | 42 | 0 | 0 |
| 5 | Locked | 41 | 0 | 0 |
| 6 | Locked | 41 | 0 | 0 |
| 7 | Locked | 41 | 0 | 0 |
| 8 | Locked | 41 | 0 | 0 |
| 9 | Locked | 41 | 0 | 0 |
| 10 | Locked | 42 | 0 | 0 |
| 11 | Locked | 42 | 0 | 0 |
| 12 | Locked | 41 | 1 | 0 |
| 13 | Locked | 41 | 1 | 0 |
| 14 | Locked | 42 | 0 | 0 |
| 15 | Locked | 42 | 0 | 0 |
| 16 | Locked | 41 | 1 | 0 |
| 17 | Locked | 42 | 1 | 0 |
| 18 | Locked | 42 | 0 | 0 |
| 19 | Locked | 42 | 0 | 0 |
| 20 | Locked | 42 | 0 | 0 |
| 21 | Locked | 41 | 0 | 0 |
| 22 | Locked | 42 | 0 | 0 |
| 23 | Locked | 42 | 0 | 0 |
| 24 | Locked | 41 | 0 | 0 |
| 25 | Locked | 41 | 0 | 0 |
| 26 | Locked | 42 | 0 | 0 |
| 27 | Locked | 41 | 0 | 0 |
| 28 | Locked | 41 | 0 | 0 |
| 29 | Locked | 41 | 0 | 0 |
| 30 | Locked | 41 | 0 | 0 |
| 31 | Locked | 42 | 0 | 0 |
| Channel | Frequency (Hz) | Power (dBmV) | Symbol Rate (ksps) | Modulation | Channel ID |
| 0 | 49600000 | 46 | 5120 | QAM 64 | 1 |
| 1 | 43100000 | 45.8 | 5120 | QAM 64 | 2 |
| 2 | 36600000 | 45.5 | 5120 | QAM 64 | 3 |
| 3 | 30100000 | 45 | 5120 | QAM 64 | 4 |
| 4 | 23600000 | 45 | 5120 | QAM 64 | 5 |
| Channel | Channel Type | T1 Timeouts | T2 Timeouts | T3 Timeouts | T4 Timeouts |
| 0 | ATDMA | 0 | 0 | 0 | 0 |
| 1 | ATDMA | 0 | 0 | 0 | 0 |
| 2 | ATDMA | 0 | 0 | 0 | 0 |
| 3 | ATDMA | 0 | 0 | 0 | 0 |
| 4 | ATDMA | 0 | 0 | 0 | 0 |
Ahh probably not going to make any real difference for now anyway. Still might see if they will send me one out, although I doubt they will with me being on hub 4.Has Wifi 6 and a 2.5g port, otherwise nothing different. It is slightly quicker, for me, when using 2.5gig network port.
Thank you. I’ve just ordered it. I’ve never had any issues with hub 4 to be honest but I mean who doesn’t want the latest?Yep, fill in this form: https://www.virginmedia.com/offers/vsfd05w5446uydfgfhfvbhxc20b5u78cfbxxxashub5 Wait around a week and then it should be confirmed. Not sure if there's much difference other than the Wifi 6 and 2.5g port. It does have a Broadcom SoC, compared to the Intel Puma 7 in the Hub 4. Not sure if there was still an issue with the Puma 7, compared to the 6 in the Hub 3.
BQM is pretty much the same. Slight increase in minimum latency:
Well it’s just gave me a delivery date and confirmation so hopefully l receive mine. If not I’ll do that as wellI had a hub4 previously. First time I filled in the form it was rejected so I did it again and they sent me one.![]()
Signed up last week for the Volt Ultimate and waiting for the install next week.
Last time I had VM SH3 I ran it in modem mode with a 3rd party router, is the SH5 better or should I also run it in modem mode?
Its with the 1130mbps Internet package.
Dead link
Dead link
Going by the Hub5 mine has 5 but I don't remember how many it had before?
