That has randomly happened a few times to me. Restarting my PC (sometimes twice) fixes it.Just installed 22.10.2 (and reinstalled after using DDU) and HDR option is missing from Windows. Bummer.
Yeah, a restart did the trick after the first install but neither a restart nor shutdown helped after. Very weird one.That has randomly happened a few times to me. Restarting my PC (sometimes twice) fixes it.
Just remember don't enable 10-Bit Pixel Format in Global Graphics or HDR is not supported. 10 Bit colour can be enabled in the Display tab of AMD Software.
A fresh Windows install can fix a whole host of gremlins!Fresh install of Windows and all drivers including 22.10.2 on both my PC's and have encountered no issues at all as yet?
AMD Software: Adrenalin Edition 22.11.1 Release Notes
Article Number
RN-RAD-WIN-22-11-1
Highlights
- Support for:
- Call of Duty®: Warzone 2.0
- Marvel’s Spider-Man: Miles Morales™
Fixed Issues
- World Of Warships prediction lines may be missing on Radeon™ RX 6000 series GPUs.
- When Radeon™ Anti-Lag is enabled, a beep can be heard when pressing the shift + back key.
- OpenGL applications using MSAA may see visual corruption.
- Higher than expected idle VRAM clock using multi-monitor setups on Radeon™ RX 6000 series GPUs
- Selected objects may be missing in Edificius™.
Known Issues
- During video playback and window switching, an intermittent driver timeout or black screen may occur on Radeon™ RX 6000 series GPUs using some 240Hz refresh rate displays or high refresh rate primary display plus low refresh rate secondary display configurations.
- GPU utilization may be stuck at 100% in Radeon performance metrics after closing games on some AMD Graphics Products such as Radeon™ 570.
- Stuttering may occur during video playback using hardware acceleration with Firefox on some AMD Graphics Products such as the Radeon™ RX 6900 XT.
- Brief display corruption may occur when switching between video and game windows on some AMD Graphics Products such as the Radeon™ RX 6700 XT.
Important Notes
- AMD Software Capture and Stream features and Overlay support for Clone mode and Eyefinity display configurations will be introduced at a later date.
I've seen some monitors trigger higher idle state at 120hz and 144hz while other monitors don't at the same refresh rate. My 32" 1440p 75hz monitor will keep my 6700xt at higher idle state at 75hz but not at 60hz while my 27" 1440p don't no matter if its run at 60hz, 144hz or 165hz, all run as single monitor setup. If i recall correctly @LtMatt said something about it being due to vblack settings of the monitor itself triggering this behaviour. If this is correct and normal or a bug I couldn't tell you.Just installed these and...
"Higher than expected idle VRAM clock using multi-monitor setups on Radeon™ RX 6000 series GPUs"
Is not fixed for me, or at least my 6700XT behaves as it always has, though we've been told in the past that high mem clocks with multiple displays is to be expected and is normal behaviour.
So not really sure what's expected or what this is attempting to fix?
Main monitor is 1440p@144Hz, second monitor is 1080p.
If I run the second monitor at it's max 120Hz, then mem clock is always at max with ~30W GPU at idle.
If I run it at 60Hz then mem clocks down to ~30MHz and ~6W GPU at idle.
"Stuttering may occur during video playback using hardware acceleration with Firefox on some AMD Graphics Products such as the Radeon™ RX 6900 XT."
I'm wondering/hoping this is related to the higher decode usage and stuttering playback of 4K videos etc I talked about earlier in this thread that's been an issue for a year now.
The other known issues I don't seem to suffer from but have seen a lot of people saying they've had good results from disabling 'MPO' Multiplane Overlay, seems it's been affecting nVidia users as well...
NVIDIA Support
nvidia.custhelp.com
seen a lot of people saying disabling this has fixed a lot of their odd driver behaviour.
