Man of Honour
- 16 Jul 2009
- Edinburgh
Does anyone have FM 2023? does it run fine on the Deck?
Not sure about 2023 but 2022 ran fine, albeit I used the 2D Match Engine
Yep, via Windows though haha. I've completely wiped the internal SSD now and using Windows permanent. TDP and refresh rate settings are all a button combo away. Really loving it. Everything just works.Does anyone have FM 2023? does it run fine on the Deck?
I had this one before I sold my Steam Deck and was really pleased with it: https://www.amazon.co.uk/gp/product/B0B2WJNXYT/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I'm thinking about picking up another one now and would buy this again
Did you get a USB C magnetic port that supported the extra power the deck needs? When I looked last time the ones that actually listed it were only 2A ish
mine took 5 working days last week. GLS shipping their end (Netherlands) and Royal Mail Parcel Force this endHow are delivery times these days and which courier?
I've got it installed through boilr so assume that is direct exe.Seems okay here, I mean performance drops below 30 at times and frame times can look a bit sketch particularly when driving but not bad given the specs. Are you always getting only 25fps and do you have an example of one of the YT vids. Personally I just selected the steam deck profile in graphics menu then turned everything down another notch.
Could also try just adding the .exe directly to steam and not via heroic since GOG version has no DRM.
Just got my shipping email, when can I expect it to arrive?
Unlike most, I want it to arrive next Monday when I'm back in town, hopefully it won't be this week...
Good to know, looks like I've timed it perfectly thenNot this week. They always ship on a Tuesday, they do it in batches. It takes a week.
No...Mine wasn't with PF.Can you choose another courier? I don't trust PF.
Not yet: https://help.steampowered.com/en/faqs/view/6121-ECCD-D643-BAA8can windows and steam os both be setup on the ssd to dual boot and then both use the same sd card for additional storage?
