- 18 Feb 2007
- London
I forgot to reply back. This is on a 12.9" iPad Pro 2019 (3rd gen?) model.
1. Literally my first 5mins were spent trying to work out why opening a folder leaves an ugly gap at the top of the screen. Seen a lot of complaints about this one as it was apparently in the previous RC and yet not picked up by 'QA'.
Reddit - Dive into anything
www.reddit.com
2. Apple Pencil seems to lag in notes like crazy. Thought it was me but I've seen it mentioned a few times on reddit.
www.reddit.com
3. Opening certain apps results in a black screen animation before the app appears. I haven't used the iPad much since I updated. So far YouTube, Mail, Notes and Reminders do this.
www.reddit.com
4. Sometimes when I go from Portrait to Landscape, the orientation sticks. It used to happen before mind you but very occasionally. On the first night of upgrading it happened 5 times in an hour.
5. Icons on the dock are shifty...last night I tapped on Mail and File Browser (an app) appeared. I got confused so tapped on Safari and Mail appeared.
Edit: Forgot to mention that the keyboard is odd when it comes to composing text in an app that is set as a floating window ie telegram. The keyboard just covers the text input box so you end up typing blindly. I ran out of time tonight to mess with the device.
I've never ever had issues upgrading iOS so this smacks of a BS update. Does anyone know if I can downgrade?
Thanks pal, I might hold then, I have the same gen iPad Pro as you I think, just the smaller size. Hopefully these issues will get fixed soon.
