The eSIM Thread
1 Nov 2007
England
As Apple seems to be pushing eSIM heavily, I thought it would be helpful to list and perhaps rate all the UK mobile phone networks that support eSIMs. I need to change my network and have been looking into an eSIM, but there doesn't seem to be all that much information on what providers fully support eSIM.
So what networks support eSIM, and how good are they?
EE, doubt I'll move away from them. I've been with all the others and EE to me at least, seem best for coverage, (lack of) congestion, and speed.
The only problem I have with EE is that they are so expensive. I'm currently on this plan with Smarty:
and it suites me fine. Just no eSIM support.
@ChrisD. same here, I have the BT Sport app through EE and some other devices too with them. im in the eco system for them but there service (maybe not the cheapest) but overall I really like them.
I get 5G with Vodafone at home, and only 4G with EE. My work phone is with Vodafone. I'd still choose EE.
Thanks. I've ordered a free SIM card from EE for the £10 plan. I see they do data rollover, which is good as it means I probably won't have to upgrade my plan if I need a temporary data boost. Will switch it to an eSIM once I've ported my number over.
Another +1 for EE... Have tried other networks over the years and they are pants for coverage/speed/reliability/responsiveness compared to EE.
What happens if you need to send your phone off for repair? With a physical sim, you’d take it out and can put in a spare phone, but with an esim I’d assume you’d be stuck. Can anyone advise?
Very good question and something I have thought about it.
I just recently converted my voda physical sim to an esim. Works perfectly fine and when I am travelling I can just stick another sim in and use that for data and roaming etc.
I've transferred my number over to EE and subscribed to the £10 pack, but I can't find the number for voicemail. Sorry for the stupid question.
EE uses Visual Voicemail. Open the phone app and in the bottom right corner there's a voicemail button.
EE, O2, Vodafone and Virgin Media.
EE one should work well as they were Apple’s development partner for this technology.
I've switched over now, and I'm pretty pleased. My home broadband went out for about 4 hours on Sunday, and using my iPhone as a hotspot with EE worked well. The only query I have now is that you need to be an EE contract owner to switch to eSIM. They don't support eSIMs on their PAYG plans which is a shame. I'm currently on the 5GB of data, 500 minutes of calls and unlimited texts subscription for £10 a month. I need an eSIM as I need the physical SIM slot for my business mobile phone number. If I have to take out a 12 or 24-month contract, I'll consider it, but I just thought I'd ask here to see if anyone had any options before I make the move.
