- 22 Dec 2006
- Around Town
I don't drink and Lindt is for myselfIt would be a long time between visits if I was offered mint chocolate and lambs navy rum upon arrival.
Fan of modded GBAs huh?
- The GBA is modded, the game gear is modded, both the minis are modded, the master system is also modded. Literally everything on the shelf has been repaired or had a load of mods at some point
Nice small office tellyNew telly for the office
Would you mind saying where you got that shelf unit from? I like it!
Ikea do those: https://www.ikea.com/gb/en/p/fjaellbo-shelving-unit-black-70339291/Would you mind saying where you got that shelf unit from? I like it!
Oil and filter, not sure a lot on here use the suction method (Sealy suction tool is excellent) but I got 280k miles out of the last car and it was still sweet, also in their wisdom vw group used an alloy thread on the sump plus it's all carried out easily while I drink coffee......
Nah but if using the old method you still have to have the car perfectly flat or oil may be left behind, it also takes the exact 4.3l it needs. As said though no issues, you can wiggle the pipe to explore the sumpDo you check the drain plug after to see if any is left behind?
Edit /there is afew for and against vids on YouTube but it's a method I personally won't change
Not something I have used or seen when I was at VW, but if it removes all, then not too bad.
I would still have to crack the nut though to check![]()
i didn't see one when i did my Ford apprenticeship but that was back in the day i remember going to Daventry on the fuel injection course , a lot better than changing the diaphragms or setting float levels, cleaning out jets , also did my time changing points and the condenser
Why so many different types?Bought some liquid & capsules for the washine machine
I went to their new place in Daventry a few years ago when it just opened, quite an impressive place
WTAFBought some liquid & capsules for the washine machine
VW specifically suck the oil out these days, they don’t touch the drain bung![]()
