Car borked
The RAC guy plugged into my car but I don't recall if he found anything or what he said.
No, he said it sounded like there was no compression.
Im off to collect my courtesy car now so will then pop into the garage its been towed to and see what they say, probably they haven't looked at it yet though.
So he guessed.
Great!
Yeah i'd guess at something cambelt related, the sound of an engine with no compression as others have said is very different and an RAC guy would spot that straight away.
Best case is its stripped a bit of the belt and jumped a few teeth or the tensioner failed and the it's now spinning over with the timing all out of whack causing no compression, if you didn't hear any scary clattering noises it could just be as simple as a new timing belt + associated stuff like tensioners.
But it could also very easily have belt a valve and then you're getting into who knows territory.
Just popped into garage where it's sitting and had a quick look over with the guy there. The cambelt is in place and turning the camshaft gears, so is the aux belt by the looks of it but he said they'll need to have a good look, set up the timing again and see if it starts. If there is engine damage, they don't do that sort of work there.
They can't get to it till Monday so just wait and see now.
I have bent valves in more than one vehicle without hearing any kind of scary noises. One just backfired out the carburettor, and the other just quietly died.
Hopefully this is not the case here!
Speculation at this point still but if it is something serious like an engine rebuild and the garage it's at can't do that, then what do I do? The car is stuck undriveable at a garage that can't repair it.
That depends on what you want to do with it.
You either get it recovered to somewhere that can do the work or get it picked up from them for scrap.
Will they really not pull the head off and send it to an engineering shop to have the valves replaced if they're bent?
What kind of garage is this?
to be fair, I doubt most garages will do that kind of work these days. It’s reasonably specialised and very labour intensive. No main dealers would do that kind of work, they would just whack in a new engine and call it done.
On a 15 year old Mondeo, it’s just not worth paying paying someone to rebuild the engine for you. The cost to repair will be more than the cars value. The cost to repair the engine will probably be more than replacing it with a used one on a car that old.
The sound of an engine cranking with no compression is very different to the sound of an engine cranking normally. I would expect any mobile mechanic/RAC-type body to be able to tell the difference immediately.
This does seem like jumped teeth. The other alternative is a snapped camshaft but that's pretty unlikely
ebay it and move on
yeap i see another mondeo add on ebay ...someone will buy it and replace the engine, i think most true garages seem to have stopped rebuilding, you may be lucky and find a small engineering shop who would take it on.
put it on a 7 day auction see what she brings, people will bid.
no idea what it can bring but spending that outlay on a 2007 mondeo is a no no.
I've had the confirmation, engine is dead.
Scrap value is £480, they will come and collect.
Now I need a replacement car quite quick.
I could spend upto £5k but I'm concerned that even that amount still puts me in old high miler territory with a lot of risk.
Do you need a big car the size of a mondeo?
Did they confirm what actually happened to it?
Shame, I only sold my Mondeo 2.5T a few weeks ago for almost nothing. It had an engine rebuild at about 70k (thread on here somewhere) and lasted me another 5-6 years through to 120k. I really loved it.
Back in 2016 my engine rebuild cost me less than £2k at a specialist.
