by the way, are you planning on overclocking cpu? If not, may be worth looking a the B660 boards
package decent price so ignore the p500a with cooler, unless you like it..had to go elsewhere for similar but found
same 32 gb lpx corsair 3600c18 ram £106.66..for £112 can go vengeance pro rgb 3200C16 which will run along same lines as 3600c18 interchangeable with 3200c16 as one faster with looser timing, other opposite
dif motherboard, and need to find out a bit more but couple reviews so far have it well regarded..NZXT N7 board reduced to £229.99 from £264.98 at the mo........edit..ignore this board...it's just not as good as the below, so why bother
same 12600kf for £289.99
H100i (240mm)elite capelix for £115 or h115i (280mm)elite cappelix for £111
bit of a faff buying away, but an alternative anyway for diff look etc
I just looked at that bundle..for £20 more I'd 100% take the tomahawk over the aorus elite board..also be tempted by the kingston ram £5 get a bit of rgb and c17 timing rather than c18( i just prefer the look of the kingston tbh)..the 360mm aio not really needed for a 12600kf, but if you get a case with a 360mm fitting in roof, will be nice, and you know if can cool a more powerful cpu..
