A three bar electric fire? You are probably correct.It will be a monumental upgrade compared to whatever you got now..
Is there anything coming out on PC in the next 6mths or so that you are desperately wanting to play, that demands 4090 levels of power?
Apart from specialist multi monitor set ups for racing & flight simulators, I'll be damned if I can think of any PC game due in that time frame that does require a 4090, then get one, if its a GPU itch you desperately need to scratch.
Otherwise spending the best part of £2K for a bunch of crappy console ports, or just replaying games you've already played through but at higher resolution & detail, seems like the best way to throw that £2K down the drain, IMO.
Gaming in VR with high resolution VR headsets is also a use of a 4090.
3rd of November will be worth the wait one way or the other.
Buy now or pay even more later once the Ti model lands or the replacement 5000 series.Buy now or later?
Whilst I'm sure the new AMD cards will be very good, I have absolutely zero faith in AMD's ability to deliver cards in any sort of meaningful quantity, especially to the UK market, until well into Q2 2023.
So, whilst people keep saying the 3rd of November...its not really.
As a 3080 owner gaming at 3440x1440 I plan to wait for 50XX series - I don't believe I'll see true benefit from upgrading.
AMD is gay?Wait as the atx 3.0 power supplys may have problems as well, plus amd is coming out soon.
