- 13 Mar 2006
Got my Ek waterbclock on my 4090FE last night and I am disappointed in EK.
Quality of the waterblock is shocking, no where near the levels they used to be.
The block doesnt cover the whole board and as such there are two LR22 phases right next to the power connector which are uncooled.
Not convinced that the thermal pads they send with the block make a good contact all over. I put it all together and stripped it down and there is very little pressure on the pads.
Same with the gpu chip. Nvidia has a very strong spring which clamps their block in good contact with the gpu, the ek waterblock just uses 4 small screws. There dint seem to be much pressure and there is a warning not to overtighten as you could crack the chip (thats the problem you get when not using a big spring.
And lastly, i didnt get much time to do much testing last night but bearing in mind its on its own watercooling circuit with a 560mm rad and 280 rad, the gpu still gets to 60C in gaming.
And thats not even doing any overclocking. But something weird going on power wise I think, I never go above 48% power and never draws more than 280w but it was boosting to between 2850 and just over 3000 last night.
I wish I had waited for waterblock reviews as some of the other blocks available look much better and covers the whole circuit board.
Something sounds wrong there - does the GPU core TIM pattern look like it's making good contact? Almost sounds like some of the thermal pads are too thick or something
