Yes your card is totally fine.So keep card?
Sigh.So keep card?
Someone said:"I have to say a few words about this as I also had this issue (black screen and TDR error at idle) with an Asus Strix OC:
I am 100% sure, that this issue is at least partially related to the card hardware or the GPU itself for the following reasons:
I have returned the Asus Strix that I had this issue with and since then also had a Gigabyte Gaming OC as well as the NVidia FE in the very same PC and have not had this issue with the latter two cards at all, the setup being exactly the same otherwise. I had even tried the 12VHPWR adapter, that came with the Gigabyte card, with the Asus card to rule anything but the card out, but of course that didn't help for the Asus card.
I had tried dozens of things like you guys tried here in the thread, I tried with three different PSUs, I tried the card in two completely different PCs (AMD and Intel), with ReBAR on or off, with DOCP on or off. This is in my opinion all a waste of time. If you have this issue in idle, then you have a card that has an hardware issue and you probably better return or RMA it.
The only thing that "worked" for the Asus card was setting the power management mode to maximum performance, like many of you here have also experienced, which leads to the card consuming 60-70W in idle and constantly running at the boost clock rate instead of 210 MHz when idle.
I didn't need to set the Gigabyte card to maximum performance in order for it not to crash, nor do I have to do that for the 4090 FE.
Maybe this issue can be cured by a BIOS update or a driver update, but for sure the root cause is related to the card itself."
So it can be my card is faulty , if root cause is related to the card itself?
does your card boost to 3,000,000 MHz? if it doesn't, return it.Someone said:"I have to say a few words about this as I also had this issue (black screen and TDR error at idle) with an Asus Strix OC:
why 3,000,000 MHz?does your card boost to 3,000,000 MHz? if it doesn't, return it.
.it was a joke.why 3,000,000 MHz?
oook thxIt happened once, keep the damn card, turn off any and all monitoring software and just enjoy it.
sorry dont ban me please. I like you all here.Guys this is his game, just ignore him..
If you read his posts and the recent other threads one locked today that was started today by him and one still open...
Unplugged 3090 Ti. Plugged Rtx 4090. Black screen in first post and red light in mobo
Hi. I have 12900K stock 32 GB 2x16 GB DDR4 3600mhz Palit Gamerock Pro OC rtx 4090 1300W Seasonic Platinum Prime Windows 11 2H22. Updated new nvidia drivers. I unplugged 3090 ti. And plugged Rtx 4090. And on first boot was black screen ( no signal ) on monitor, and motherboard was lightning...forums.overclockers.co.uk
RTX 4090 Not utilize 100% GPU on 12900K
So I just installed my rtx 4090. Everything is working fine but for whatever reason it isn't utilizing 100% of my GPU. I have 12900K stock,DDR4 3600mhz 2x16gb. Far Cry 6- 60% usage with 1440P DXR ON,ultra Watch Dogs Legion 1440P - 60% usage with 1440P,RT ULTRA,DLSS QUALITY. CP77 observation...forums.overclockers.co.uk
He thinks he's being funny but not realising he's adding more proof for him to end up with his account closed here too, he's already been banned on other forums for this.
i m really sorry. Yes close the topic.Then stop the silly threads mate, you are wasting peoples time as I explained to you before, people here want to help but help with real issues, not ones you are making up and leading people on with.
