Hostile_18
Hostile_18
I've seen the Tuf for £350 less than OCUK are charging. Getting beyond a joke here, I have to say.
That's... not great. Don't EK have a history of sending out wrong thickness pads before as well?turns out there is meant to be a slip of paper somewhere in my ek waterblock box which states that i should use the 0.8mm and 1mm pads and not the 1mm and 1.5mm pads as it states in the instruction book! Sadly i used the online instructions on EK website which they havent updated whioch still says 1mm and 1.5mm so I am going to strip down the block this weekedn and redo it.
Ek really need to put an update on their website rather than rely on a slip of paper amendment!!!!
Seems evga have a few of those they're getting rid of..
why it just means they get b ent to a U angle instead of an L anglePower connector on the rear of the EVGA card is how it should have been as standard including the founders considering the size of the cards. At least one company had some common sense.
lots of cases, maybe even the majority have cable routing at the side of the card anyway
The 4080 12gb was the distraction card as it was so obviously poor, it's job was to take the spotlight off the 16gb so that one could go in under the radar.Hmm did not realise the 4080 16GB was so low, I knew the 12GB (now cancelled lol) was low anyway because it's basically a different card, but not the 16GB. Ah well!
The whole GPU market is a joke and has been for 2 years now, consumers really need to take a stand against this BS else top end cards will be 4K in a couple of years and midrange will be pushing 2k.I've seen the Tuf for £350 less than OCUK are charging. Getting beyond a joke here, I have to say.
Curtis vincent in Breaking badI spoke to @Curtis vincent yesterday (before this all became a thing) regarding his sale and he seemed just to be someone who had changed his mind post AMD launch, I know it’s not great to try and add a bit more on top of rrp but I completely understand the temptation (and if you don’t then I don’t believe you). The reaction on here to it has been a bit hyperbolic imo.
According to hardware leaker Kopite7kimi, the unlaunched RTX 4080 12GB becomes the RTX 4070 Ti with a possibly launch date in January.
https://videocardz.com/newz/nvidia-...-canceled-rtx-4080-12gb-sku-launch-in-janaury
great chart. Really drives home that the 4080 16gb is nothing more than a 4070 in disguise.4080 16gb is trash tier and should have been a 4070 for 600 quid.
