Safe voltage for DDR4 ?
19 Feb 2007
Northampton
Want to tweak my memory and was wondering if anyone knew the max safe voltage for DDR4 Micron equipped modules ? I've looked around but found a lot of contradictory information.
You'll probably get differing replies but here's my take ,
Samsung B Die 1.5v
Micron 1.45v
Keep an eye on temps but to much voltage stabilty will be affected
Depends on the IC, 8gbit rev e and 16gbit rev B can happily take over 1.55V however for the other ICs I wouldnt go over 1.35 vdimm.
As youve said its Rev E the safe vDimm level would be around 1.5-1.55 with higher voltages you may need to offset vttddr down to 0.7ishV.
I would recommend not going more than 1.4V. it is important to note that 1.5v is the maximum safe voltage and that running your modules at this voltage may cause them to become unstable or even fail.
1.5 is absolutely safe and fine for Micron Rev E, with up to 1.55v being fine
based on what info?
based on info collected from friends who have ran their Rev E at 1.55 to 1.6v for the past 1-2 years with no degredation, and others in OC community who have been overclocking it since it came to market in 2017/2018.
At higher voltages you might benefit from lowering DDR termination voltage though
So based on nothing then sorry I thought tou was in contact with micron...
If I say 1.75 is good and your ram dies is this ok because mine didn't?
And I say well my mate buddy's bobs best friends hair dress knows a lad who said his vet talked a a doctor whos gynaecology ones said it was ok a run 1.75
