- 21 Dec 2019
- Planet Thanet
Personally I would prefer those fans to be
Intaking cool air from outside
That's one disadvantage with hardline tubing
Not as easy to change stuff
The amount you're spending probably get a radiator just in case
Maybe test both methods first with soft Tubing
For some of the loop?
Making it easier to add or remove that radiator as required
