I got the Zotac Trinity non-OCWhich Zotak 4090 did you get?
Try reinstalling armoury crate as works fine on mine as in the FE does the same stuff as everything else like mb and distroplate etc . Only thing that doesn't change is the GeForce RTX logo.What are you FE owners using to change the rgb on top of the card - when I try and use ASUS Armoury Crate it just makes the top RGB flash. is there some other software available to change the colour?
4090 FE did. 4080 FE is due 16th November 2022.
Your best chance is to get the Telegram app on your phone and join FE part notification groupAssume you just need to keep checking Nvidia site? or have they all gone?
they sell out in 2 mins give or take so need to be quick for the FE.Try reinstalling armoury crate as works fine on mine as in the FE does the same stuff as everything else like mb and distroplate etc . Only thing that doesn't change is the GeForce RTX logo.
I tried that but it didn't seem to want to workI’ve been using EVGA Precision software to adjust both the top light and the logo on the FE.
Only a little like the 3000 series , its just a < shape strip next to the fan and is pretty discrete tbh although the Geforce RTX logo is pretty brightWait the 4090 FE has RGB?
Cheers for that I'll try that on my Inno as their Tuneit software is not controlling my RGB I can't switch it off or change anything lol, Doesn't surprise me though Zotacs Firestorm I had for the 3080 was pos also that never worked half the time.SignalRGB. It’ll control all of your lights, regardless of manufacturer.
If you pay for an annual subscription it’ll also control your fan profiles too.
It’s probably the best universal RGB app I’ve found that can control everything.
Thank me later![]()
You have to keep the button depressed until the card flashes red (default) or blue (quiet), then reboot for it to take effect.My Zotac had buzzing fans that sounded like coil whine but was 100% from the fans as set to 0% buzzing stops ... To change the fan bios on the zotac you need to use their Firestorm utility and will have an option to switch bios and will require a restart to take effect , im not sure what that button does but didn't change the bios when i pressed it
I have a 4090 FE now and the fan pitch isn't nice tbh and is rather loud although it doesn't buzz , it does have noticeable coil whine though but not enough for me to be bothered by it .
Yeah it's a pain in the ass having to have so many conflicting software to get all the components working as intended, One thing I've noticed from the last 2 GPU's i've owned from 2 different manufacturers it's always the RGB on GPU's that have issue's, I don't have AURA installed or enabled as I'm using the Corsair commander pro with my QL fans now whether that Icue software is causing my GPU software not to work I have no idea but i'll give that a shot when I get the chance thank you!It got to a point where I had ASUS aura, Corsair iCue, HyperX RGB and STILL certain things like case LEDs wouldn’t play nice because of the conflicting apps… found this and haven’t looked back.
I do pay for the annual subscription but it’s just a great piece of kit.
Cooling isn't to bad tbh , it will sit high 60 ( 68/69 ) in my case which tbh is less than ideal for an air cooled card ( air heated by rads ) .... i had a Zotac aib previously with 3 fans and this cools just as well . The only down side is when set to 100% this FE is very loud and the fans have a horrible pitch but only do that when benchmarking so not an issue for meThis is the first time I've seen such a fan design. How is the cooling??
Oh is there an option for that in Armoury Crate ? ( dimming the logo )You can dim the logo or turn it off altogether, along with the strip if so desired.
