- 16 Jan 2003
- Nottingham
I’ve noticed iPhone 14 series phones are no longer listed as coming soon for true play, anyone able to test?
Just a quick heads up if you’re thinking of buying either Sonos are doing Black Friday pricing for 10 days from the 18th. Arc will be down to £699 and the beam 2 £349.
Thinking of getting a Beam 2 plus Sub Mini. Daft question but how does volumes control work? Is it just via HDMI ARC and your TV remote?
Also, I already have 1 x Play One in the living room. Would it use this as a rear channel despite there only being one of them?
I’ve been holding out for Black Friday so good to see there will be some nice savings!
Are there any options with Sonos for using it as a PC speaker and as a “normal” Sonos speaker? It would need no delay though which I had previously with a Bluetooth speaker.
Perfect! How are they connected to the PC?I have my PC running on a Beam 2, two 3s for rears and a sub and it is fantastic, so yes!
It also functions as you would expect Sonos to do with all the other Sonos in the house.
It's the opposite for me, the sound in my study from 2 x Play 1 and a Sub Mini is definitely flatter than it was prior to the update. Bass is good, but the mid range is pretty poor.
Edit - Following another Trueplay tuning and a few days usage the sound is greatly improved.
I'm tempted to get a Beam to replace the dated Playbar in the bedroom.
