Man of Honour
- 5 Jun 2003
- Falling...
Well I tried adding my nest door bell... needless to say my mind was somewhat blown at it! I might need a bit more coffee / time to work it out!
You follow these instructions?Well I tried adding my nest door bell... needless to say my mind was somewhat blown at it! I might need a bit more coffee / time to work it out!![]()
Have set up smart things, can't recall it's complexity - you hitting any problems?Some integrations go from 0 to 11 complexity pretty quick. SmartThings, for example...
Gave me after reading the summary page but it involved being a premium member and setting up an API broker iirc.Have set up smart things, can't recall it's complexity - you hitting any problems?
Any thoughts how I go about setting up an automation that turns a switch on at 7:30 - 16:00 Mon-Fri for two weeks then on the third week switch on at 10:00-18:00 for a full week?
Interesting thought - apologies for the stupid initial question, but does this not happen automatically anyway?!I've thought of a a good thing I'd like to explore.
If we've had a good solar day and the myenergi solar diverter has heated up the hot water, I'd like it to turn off / pause the hot water schedule on my hive. If the water temp drops too much to renable the hive schedule (it comes on for 20 mins in the morning and 20 mins in the evening), or potentialy it could boost give for 15 mins or so. In the winter I forsee using gas generally - but some days we've had enough sone for some solar heating.
There's definitely going to be a thermostat in the tank - otherwise as Katie says you might end up boiling it!Well that's the thing I'm not sure. We use gas for the heating and the hot water. But the myenergi will see what the temp of the tank is and then decide to heat the water or not based on solar excess.
At the moment the gas comes on a schedule. The hive is relatively "dumb" i.e. if the water is hot the boiler will still kick in as it's on a timer unless I've got it badly set up?
Perhaps hive doesn't kick in automatically if the water is hot? I'm really not sure.
So if I have the gas on schedule and the water is hot it won't turn on? I've never tested it to be fair and never even considered it! Makes perfect sense! In fact that kinda explains the birds nest of cables in the junction box, one of them does go to the thermostat. I'll need to take a closer look.
