Only a few more sleeps to go
Reading that it uses microwaves to send the power down…. Not sure I’d want to be cooked by a misaligned signalhttps://www.bbc.co.uk/news/science-environment-62982113 Wonder if this will generate more than @katie279's array on a sunny day?
Would you believe it!!! the 2nd quote again not my roof lol but they are getting closerSo received another virtual quote lol its not my roof!!! and totally ignored my email with all the info on, including what mfg inverter and battery I wanted. Even gave them 3 little words.
I did look at GivEnergy, but their inverter isn't big enough.
Specifically, in the case of the GivHY-5.0, it can input 6500W from DC, but output only output 3600W via the battery (with a maximum of 5000W if the PV panels are generating).Are you talking power in or power out? If you are wanting a 20 panel system, then you'll be looking at 7-8kWp depending on the exact panels used, and the largest dedicated single phase PV inverter you can get is ~8kW, although there are hybrid ones which are larger, the Sunsynk is 8.8kWp PV, and 8800VA AC output, they are ~£1,800
Currently showing 154KWh generated for the month, so that seems reasonably good, 1.29KWh yesterday which is the worst day so far I think (I have one day showing as 0.38 but I believe that was due to my internet being down for most of the day).
The good news about yesterday is that Octopus are doing another Saver Session today and conveniently I cooked tea yesterday using grid energy at just the right time! Though would rather be on Economy 7, been over 3 weeks since I asked to switch and still not happened, may need to get in touch.
Can you not get 2 inverters and split the array onto 2 strings one on each inverter?
Yes on some systems you can parallel inverters, I know GivEnergy don't officially support this, also you would need a battery per inverter if running hybrid and not AC coupled in order to draw load from them both.
