Panasonic arrived today, not used it yet, that's a job for the morning. But initial impressions are positive. It has some stuff I have not seen in the Brauns in the past which I quite like.
1: The build quality feels great. On par with Series 9, but because everything is matte and not glossy faced like the Brauns have, looks more premium.
2: The 5 blade head is quite chonky indeed! Also its gyro head reminds mf of those Churchill dogs you see on car parcel shelves.
3: The charge and clean station is quite cool, it does not use solution cartridges like Phillips/Braun etc use, instead has a water container where you pour in a sachet of detergent and then add water to the fill line. I checked Amazon and a pack of 3 sachets is £99, of £16.99 for 6. The manual says if used every day, then the cleaning tank should be refreshed once a month. I only intend on using it once a week or so and just tap water clean other times.
4: the shaver has an ultrasonic cleaning mode where if you are cleaning with hand soap and under a tap, this mode doesn't activate the full motors and only ultrasonicsly vibrates the blades meaning no water splash which I got on previous shavers.
5: The cleaner unit has a drying fan built in too, on past Braun clean & renew stations you had to buy the unit with drying fan as an optional extra as the shaver came with just the clean and renew station without drying. The fan sounds like a Delta case fan from the early 2000s
- The cleaning process itself is quiet and takes several minutes. teh drying process takes up to an hour depending on ambient temps according to the manual.
Media:
Videos for sound of the clean/dry process:
