Yeah, but the card sizes i mean e.g.What do you mean by default dashboard? You can just create what you want and have a full screen camera view if you want?
Yeah, this is more about web design than HA (ie same in Bootstrap, Material and so on).Yeah, but the card sizes i mean e.g.
The white boxes are camera streams. I want them to be bigger, maybe two cards wide and high. Is that possible?
The tutorials etc I've watched don't show resizing cards![]()
Yup, as above - look at the grid card:Thanks, that's useful. However, I don't know if I'm expecting too much but it would be nice to do like...
Blues are cameras, oranges other random stuff eg climate...
 and so on.That's really nice Andy!Been working on an updated dashboard for my wall mounted tablet this evening, far from finished yet as I'm not happy with a lot of things. But it's coming together. Would like to improve on alignment of things and got a few bits to add yet also.
ThanksThat's really nice Andy!
Haven't seen that weather bar chart - assume the coloured bits show min and max ranges?
That looks awesome, gives me a target![]()
Fair enough, quicker to get the ideas elsewhere I guessThanks
Yea that’s right it’s the min/max for the day. Pretty sure it’s the Mushroom cards weather card.
Cheers haha. I keep having to search Reddit and forums for ideas so it’s not all my own work, a case of bringing various ideas together until it does what I want it to.
I use fully kiosk - great wee app!Fair enough, quicker to get the ideas elsewhere I guess
Along those lines, are you using wallpanel integration to make the dashboard full screen (without the side panel and top panel) on your tablets?
To all the wallmounters out there, I was doing this, I started with Kindle fires but they were too sluggish for me so I moved to Huaweis as they had a better screen and spec and they were great (apart from the sideloading needed because of Huaweis app store).
There was a big problem though - batteries. The battery bulge on both types of tablet (i.e. malfunction and fire risk) as a result of having them on power all the time. What are you doing to prevent this - do you charge them up when needed?
Ooh, hadn't heard of firetoolbox, does this make a noticeable difference?There’s many people way more creative than I am
I’m using a combination of fully kiosk browser and browser-mod for it.
I’m using a Fire HD10 (9th Gen I think). Used firetoolbox to debloat it and it’s perfectly ok. Screen is perfectly good enough.
I ripped the battery out of it and soldered some wires up inside to run it directly off a 5v transformer. Did not want the hassle and risks of a battery either being on charge or constantly cycled.
Put the tablet on a smart plug and set an automation based on tablet battery % charged.
