- 10 Feb 2011
I think if anything is to be picked at, it is the battery life of the Quest Pro HMD...
2hrs is maxed.
USB 5V 1A (5W) using PCVR, makes hardly any difference in battery lasting any longer.
I also have a cable that connects to a wall socket and PC, but that is also limited to 5V 2A (10W) this also doesn't improve the battery life much...
Running Air link, and plugged into the wall, the HMD doesn't drain.
Shouldnt the typec usb 3.0 be enough to charge it using PC while running?.
