Ive been using these for a good few yrs, and they do a ok job https://www.amazon.co.uk/Wahl-Clipp...t=&hvlocphy=1007072&hvtargid=pla-931796897993
Lol I shall grow the beard til it's arrival just so I can see it's true cutting powerDon't mention me specifically, because now that means if it doesn't work out for you I am to blame!
People shouldn't really do this as all electric shivers even safety razors are not great when it comes to long whiskers/stubble. Your main concerns should be is, is shaving faster than with your previous shaver/razor and also the closeness and comfort of the shave. Reviewers annoy me when they let there face grow into a jungle and then says the shaver is rubbish when it cant cut through itLol I shall grow the beard til it's arrival just so I can see it's true cutting power![]()
Tbf it looks very much like my 1st choice which was the Braun 9series but I'll save £70 so it just helped with the decision. I'd referenced mrk in order to give some appreciation for the review.People shouldn't really do this as all electric shivers even safety razors are not great when it comes to long whiskers/stubble. Your main concerns should be is, is shaving faster than with your previous shaver/razor and also the closeness and comfort of the shave. Reviewers annoy me when they let there face grow into a jungle and then says the shaver is rubbish when it cant cut through it![]()
I will be using the cleaning station for storing the shaver in aswel, but will just have it plugged in to the mains when cleaning or charging the shaver. And will probably buy a shelf and have it next to my toothbrush on the bathroom wallI'm using the Panasonic dock station all the time now, just much more convenient.
You want to let the battery run down a bit though as it cant do the battery much good always charged?It actually stops feeding power when it's fully charged on the station, you have to detach it (it's magnetic) then let it sit back in to get a trickle charge check, so pretty energy efficient. I bought one of these to attach to the plug as my bathroom doesn't have a socket, so the station sits elsewhere full-time plugged in.
You can buy the cleaning station separately for the 6 series if you have somewhere to put it. Then you can keep the shaver in the station when not using it?Finally got my Braun Series 6 today. Gave it a try.
Smooth finish, no skin irritation, washes under the tap. I like it. I also like all the clippers accessories that it comes with.
My only nit pick is the charging cord is a bit short though...like really short. The old Series 3 cable is like a coiled one, this is just straight and a half the length.
This is an old thing that I don't think applies in modern batteries really. Even with phones, even though some have a setting to only charge to 85% etc and websites still say to let the battery get used but keep it within 60-80% ideally etc.You want to let the battery run down a bit though as it cant do the battery much good always charged?
