Man of Honour
- 5 Jun 2003
- Falling...
Ah, you're probably right then!Worth doublechecking the instructions above - checked the api key etc?
Also check your home assistant log - it's pretty good at saying what the problem is (eg incorrect api key etc)
Getting this error - so clearly something is wrong.
2022-12-01 15:40:09.888 WARNING (MainThread) [homeassistant.config_entries] Config entry '*****' for pvoutput integration not ready yet: PVOutput has no data available; Retrying in background
Is there a more step by step guide you can point me to?
